View Full Version : What size fits 67 camaro
I'm going to do a 2" or 3" drop. AR torque thrust II 17" or 18". How wide can I go on front and back. What kind of backspacing? I want as much lip as I can get.
TheJDMan
12-23-2019, 05:03 PM
A lot will depend on the suspension you are using and if you plan to install mini-tubs. I'm running 18x10 275s front and 18x12 335s rear but that is after a LOT of careful measuring to determine what size and backspace I needed for my suspension.
170849
Wow, I like it. Unfortunately I'll be using stock suspension. 2" block in rear, 2" spring in front
elwaupo
12-29-2019, 05:40 PM
Member
Car
Wheel Make
Wheel Model
Front Size
Front
Backspace
Rear Size
Rear Backspace
Front Tire
Size
Rear Tire Size
Suspension
Mike Knopp
67 Camaro RS
Ameri-can Racing
Torque Thrust II
17x8
4.75”
17x8
4.75”
245/45/17
255/45/17
Global West Control Arms/QA-1 Coilovers Rear: Global West Springs
Chris Robinson
67 Camaro RS
Boyd Coddington
Timeless 5
8” Wide
5”
8” Wide
5”
245/40
275/40
Stock arms lowered 1" in front rear Relocated shocks w/stock Mono-leafs
Tom McGinnity
67 Camaro
Colorado Customs
South Park
17x7
4.5”
17x8
4 7/8”
235/45/17
255/45/17
Hotchkis 1-1/8 sway bar and Hotchkis 2 inch lowering springs, all PST bushed with quick ratio box by Durex. The rear suspension is simply lowered with blocks, 2 inches on the left and 3 inches on the right
Travis Myers
67 Camaro
Fikse
FM5
18x10
Same as on the Mule
18x12.5
Same as on the Mule
275/35/18
335/30/18
Wayne Due Front Subframe
Rex
67 Camaro RS/SS
Billet Specialties
Vintec
17x8
5”
17x8
5”
245/45/17
245/45/17
Global West Cat
Gmc427
01-05-2020, 02:37 AM
do you have a build tread on your car?regards
- - - Updated - - -
jd do you have a build tread on your car?regards
TheJDMan
01-06-2020, 08:03 PM
Project "Dust Off" then and now.
https://www.pro-touring.com/threads/81109-Project-quot-Dust-Off-quot-then-and-now?highlight=Project+Dust+Off
tm5nardo
01-22-2020, 07:27 PM
17x8 will look good but might rub a little at full lock.
