      Dec 2019
      Ellenboro, NC
      What size fits 67 camaro
      I'm going to do a 2" or 3" drop. AR torque thrust II 17" or 18". How wide can I go on front and back. What kind of backspacing? I want as much lip as I can get.
      Dec 2010
      Fredericksburg, VA.
      A lot will depend on the suspension you are using and if you plan to install mini-tubs. I'm running 18x10 275s front and 18x12 335s rear but that is after a LOT of careful measuring to determine what size and backspace I needed for my suspension.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Dec 2019
      Ellenboro, NC
      Wow, I like it. Unfortunately I'll be using stock suspension. 2" block in rear, 2" spring in front
      Elk Grove, CA
      Member
      Car
      Wheel Make
      Wheel Model
      Front Size
      Front
      Backspace
      Rear Size
      Rear Backspace
      Front Tire
      Size
      Rear Tire Size
      Suspension
      Mike Knopp
      67 Camaro RS
      Ameri-can Racing
      Torque Thrust II
      17x8
      4.75”
      17x8
      4.75”
      245/45/17
      255/45/17
      Global West Control Arms/QA-1 Coilovers Rear: Global West Springs
      Chris Robinson
      67 Camaro RS
      Boyd Coddington
      Timeless 5
      8” Wide
      5”
      8” Wide
      5”
      245/40
      275/40
      Stock arms lowered 1" in front rear Relocated shocks w/stock Mono-leafs
      Tom McGinnity
      67 Camaro
      Colorado Customs
      South Park
      17x7
      4.5”
      17x8
      4 7/8”
      235/45/17
      255/45/17
      Hotchkis 1-1/8 sway bar and Hotchkis 2 inch lowering springs, all PST bushed with quick ratio box by Durex. The rear suspension is simply lowered with blocks, 2 inches on the left and 3 inches on the right
      Travis Myers
      67 Camaro
      Fikse
      FM5
      18x10
      Same as on the Mule
      18x12.5
      Same as on the Mule
      275/35/18
      335/30/18
      Wayne Due Front Subframe
      Rex
      67 Camaro RS/SS
      Billet Specialties
      Vintec
      17x8
      5”
      17x8
      5”
      245/45/17
      245/45/17
      Global West Cat
      Jun 2015
      Country Flag: New Zealand
      do you have a build tread on your car?regards
      - - - Updated - - -
      jd do you have a build tread on your car?regards
      Dec 2010
      Fredericksburg, VA.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      Apr 2015
      GA
      17x8 will look good but might rub a little at full lock.
