View Full Version : VA/CAA Install Question
AU Doc
02-09-2019, 07:10 AM
When you install an aftermarket AC system in a first gen Camaro, do you generally block off the vents in the kick panels? I’m doing my sound deadened and insulation at the same time, and it seems like it would best to cover the openings with MLV. But on the other hand, I think it would also be nice to be able to open the vents to let in fresh air.
130fe
02-09-2019, 08:07 AM
161249161250Some guys leave the stock kickpanel in and you still have “fresh” air option. I originally bought a set of screaming performance kick panels but now I am switching to The Shop, LLC ones. I switched to the aftermarket ones because I wanted a better speaker option. Both of those brands I mentioned come with a “cup” that blocks the fresh air inlet.
dontlifttoshift
02-09-2019, 11:55 AM
I keep the drivers side functional when I can.
ULTM8Z
02-09-2019, 12:09 PM
I put speakers in my kick panels a long time ago and haven't missed the fresh air vents. Even in my daily driver, I always run the A/C with the vents closed (there's no such thing as "fresh air" in Southern California anyway).
AU Doc
02-10-2019, 03:57 PM
Thanks, everyone. I think I’m going to block off the vents. I’m not one to run with the windows down or vents open very often.
badazz81z28
02-10-2019, 05:38 PM
The VA system took away my fresh air, I’m going to install non ac vent kick panels
AU Doc
02-11-2019, 07:43 AM
I've never had one of these cars with factory air. Were the kick panels different if the car had AC from the factory?
Just 1 More
02-12-2019, 05:53 AM
My VA kit came with fresh air block off plates. I just thought that was part of the deal
