    Results 1 to 6 of 6
      Nov 2011
      Country Flag: Norway
      1969 Camaro Wheel fitment
      I need some help from you professionals out there.
      Will a 17" 7" wide with 4" backspacing fit on -69 Camaro with original subframe without subbing?
      235 wide tires. ridetech A-arms and spindle!
      Rear 18" 8" wide with 4" backspacing stock rear.
      FRANCE
      Country Flag: France
      Hi Pompel
      For what I can say 69 Firebird stock SF, I run 17x8 w/ 4.5 BS & 235 tires all 4 corners without rubbing issues
      I think your front setup is fine & you can go wider too in the rear like 18x 9/9.5 with 5/5.5 BS & 265/275 tires!
      Gil
      Mar 2015
      Gil, Great looking wheel and tire set up. Looks awesome.
      FRANCE
      Jan 2011
      Boston, MA
      235 is a lot of tire to put on a 17x7 wheel.
      Ideally you would want 4.25" bs on a 7" wheel to center it in the wheel well. 4" bs will push it out 1/4" more, which should be fine with a 235.
      Nov 2011
      Thanx for all the information. Found this tool http://www.willtheyfit.com/
