    Results 1 to 12 of 12
      Jan 2015
      67 Camaro 20x10 RideTech?
      Hello to all, searched and searched and was curious to know if anyone knows or has pictures of any first Gen Camaros using ridetech and their Truturn set up but with a 20x10 up front??
      Thanks!
      Feb 2010
      I don't have a 20x10 up front but an 18x9 with a 265 tire and am running the truturn. I can tell you that I barely clear the outside fender (but it clears) on full lock when I turn the tire will kiss the frame on the back side, it can really mess you up when doing donuts but that's about it. Here is a pic for reference.....
      Jan 2015
      are you running all ride tech with the coil overs and 4 link? Looks awesome man really does perfect stance and tuck on the wheels and tires.... can't wait to finish mine. Left to the service in 2008 and left it with the shell complete, came back home to the LS frenzy and now I am cashed out! lol
      Dec 2010
      Fredericksburg, VA.
      I don't know of anyone here running a 20x10 front wheel on a 1st gen Camaro. A 20" wheel is not optimum for performance and most here are more performance oriented than that. I'm running 18x10, 275's front and 18x12, 335's rear on my 68.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Jan 2015
      Stance is so clean on that too man. Whats the BS on the 18x10's? Agree on the performance and I will probably end up running 18's up front, I've sat on this project for too long and really want to hit the streets with it.
      Jan 2015
      Any spacers? whats the BS all the way around?
      Dec 2010
      Fredericksburg, VA.
      Quote Originally Posted by ejh532 View Post
      The rear are 18x12 5.6" bs on a 57" WMS to WMS rear end width. Up front 18x10 6.6" bs but I'm running .250" spacers. I should mention that I'm running a DSE subframe. However, the ridetech 48 hour Camaro is running 18x10 wheels up front with a stock subframe and complete ridetech suspension but you would have to contact Bret to find out the bs of his wheels.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      Feb 2010
      To your question earlier, I'm not. Running ride tech suspension. I have speedtech control arms and coil overs with their torque arm out back.
      Jan 2015
      awesome thanks for all the help!
      Cincinnati Ohio
      Quote Originally Posted by TheJDMan View Post
      They are 18x10 with 5.75" backspacing. Bret and I did a test with the wheels off the camaro and put them on my nova, and they fit.
      1972 Nova Ridetech, Forgeline, Falken Tires, Wilwood, Bowler Performance Transmission, Lingenfelter Performance Engineering.
      Feb 2010
      Quote Originally Posted by Bad94 View Post
      What size tire?
      Cincinnati Ohio
      Quote Originally Posted by the owl View Post
      What size tire?
      275/35/18
