    Results 1 to 12 of 12
      Jan 2013
      Abbotsford, B.C.
      Wilwood calipers "sweating" brake fluid
      Hey PT,
      Just installed new wilwoods on the car and started to bleed the system. The fitting on the caliper is a 1/8-27 npt pipe thread and I have an adapter that goes from that to -3an for the brake lines.
      The fittings are steel Fragola pieces and I have tightened them as far as I can go before stripping out the threads on the caliper. This is where it sweats.
      Is it safe to apply some sort of thread sealant on the npt fitting? Teflon or Permatex?
      I know for the rest of the system it's all AN fittings no type of sealant is required but this has me scratching my head.
      Thanks!
      NPT threads need a Teflon sealant.
      Sep 2010
      Beach Park IL
      Make sure your adapters are in fact pipe thread. The 3/16" (3/8" 24 thread) inverted flare by -3 AN adapters will thread directly into the pipe thread on the calipers and never really seal.
      If they are pipe thread, like Andrew said, PTFE thread sealant is the answer. You can use tape, but be careful, you do not want pieces of it in the brake system.
      Donny
      Jan 2013
      Abbotsford, B.C.
      Thanks for the help guys!
      I double checked the part number and they are 1/8-27 npt.
      I checked the rest of the system and no leaks anywhere else. I thought using stainless was going to be troublesome but it has sealed just fine.
      Jun 2001
      Orlando, FL
      Loctite makes a nice Teflon paste that has given me good results with pipe thread on brake lines.
      ​John Parsons
      Jan 2013
      Abbotsford, B.C.
      Bought some Loctite thread sealant I will give it a go tomorrow and see how it goes. Thanks guy!
      Sep 2013
      Ottawa
      Something must be wrong here. The bleeder screw forms part of a valve that stops the fluid from escaping during normal operation. The threads do not form part of the seal so if it leaks I would start by inspecting the machining of the screws and the caliper. Maybe you got some bum screws, or calipers from a bad batch? Did you get the screws from Wilwood?
      Kevin Murray
      72 Skylark
      Jan 2013
      Abbotsford, B.C.
      This isn't the bleeder screw that is leaking. Its the adapter for the brake line that has a pipe thread fitting.
      Sep 2013
      Ottawa
      Ah I understand now. Sorry I missed that.
      Kevin Murray
      72 Skylark
      Oct 2006
      Stillwater Oklahoma
      Be careful tightening that pipe thread fitting also. Being that is a tapered thread it is possible to crack the housing around the thread.
      Quote Originally Posted by pist0lpete View Post
      Neal,
      Excellent point. I can't understand why Wilwood stick to damn plumbing fittings. Can't they make a caliper with a proper banjo fittings?
      Jan 2013
      Abbotsford, B.C.
      There's quite a bit of meat there. But I did split the end of the brake line. I checked the adapter to see if it was still sweating and it was! Pulled it apart and noticed the brake line fitting had a small hairline crack. Likely from me cranking on it. New line and no leak.
