    Results 1 to 4 of 4
      Jun 2012
      Wilwood hubs with Kore3 brackets
      I am installing c6 z51 brakes on a 79 z28.
      Have the rotors, calipers, abutment brackets and kore3 brackets. I need to get hubs I was going to turn my stock rotors down and make them but I don't have access to a lathe anymore.
      I can buy wildwood hubs for $112 each just not sure if the spacing is correct.
      Tim
      86 Mustang
      454 LS3 Mast 4500 intake FTI cam Holley EFI Drag radials and pump gas 9.24 143.73
      79 Z28 Bonspeed GT-B DSE front and rear Z51 Brakes 5.3 Holley EFI Vintage Air
      Sep 2013
      Ontario, Canada
      Quote Originally Posted by gray86hach View Post
      Tim
      On my A body, I used "Right Stuff" forged aluminum hubs ( cost a little over $100 pr) with Kore 3 brackets. I simply used two stacked washers (of equal thickness) as shims, between the abutment and bracket to get the caliper to sit right. Forget what the actual stacked thickness was.
      These hubs are not listed in their catalog as a separate item but if you call them they will sell them to you and they come with studs. Just another option for you.
      Tom
      Tom
      71 Buick GS, 647 HP 455, T56 Magnum/Dual Disc, C6-Z51 Kore 3, UMI/ Viking
      Jun 2012
      Ok I will call them
      Tim
      86 Mustang
      Aug 2011
      Connecticut
      Kore3 also makes hubs
      1967 Firebird "Poor-Boy Build"
      New updated thread
      https://www.pro-touring.com/threads/...bird-(Updates)
      Follow me on Instagram @NaturalLivingMan
