    Results 1 to 6 of 6
      Sep 2013
      Ottawa
      Wilwood Narrow Superlites on an A-body
      I'm shopping for a new brake system and I'm leaning toward the Narrow Superlite kit.
      http://www.summitracing.com/parts/wil-140-12271
      http://www.summitracing.com/parts/wil-140-9213
      Anyone install these on an A-body and did you have any issues? Park brake connect up easy and work well?
      Also, I'm running a 12 bolt rear and knock back is one of my concerns. Is there a fix that does not involve going to a full floating axle or c-clip eliminators?
      Kevin Murray
      72 Skylark
      Quote Originally Posted by kevmurray View Post
      I can't comment on those kits because I haven't used them, but for the rear you really should run a floating caliper to avoid pad knock back.
      Sep 2013
      Ottawa
      How does anyone get away with Z06 rear brakes on a live axle? They are popular but don't have a floating rear caliper.
      Can anyone recommend a nice brake system that has a rear floater? It seems all the serious ones are fixed.
      Kevin Murray
      72 Skylark
      Indiana
      Trust me you don't want C6 Z06 brakes without a floater, changing mine out this winter and found the thread I bumped back up to the top titled Camaro performers rear brake kit
      Aarik
      68 Camaro LS2/T56, Jake's Rod Shop C6 Subframe, JRS torque arm. Ridetech TQ Shocks
      I run the LS1 4th gen fbody rear calipers with my C6Z06 fronts. They balance out nicely.
      Sep 2013
      Ottawa
      Thanks for the info Andrew. You've been very helpful as always.
      Aarik thanks for the bump, I'll read it tonight.
      Kevin Murray
      72 Skylark
