View Full Version : Question about steering u joint
65 drop top
09-01-2014, 01:51 PM
When using the borgeson steering column u joints, are you supposed to drill a recess into the colum, dd shaft and gear box splines for the set screws? Or do you just tighten the set screws and call it a day? Thanks.
jaybee
09-01-2014, 02:29 PM
I would ABSOLUTELY drill a depression into the steering shafts where the set screws tighten. By doing so you at least have a fighting shot at catching the problem should a set screw loosen. Without that the possibility increases dramatically for something to come completely apart before you find and fix the issue.
Schwartz Performance
09-01-2014, 02:59 PM
Yep, what he said. A dab of blue Loctite doesn't hurt either , in addition to the jam nut.
-Dale
