    Results 1 to 7 of 7
      Jul 2009
      Cypress, TX
      I need a custom driveshaft
      It's finally time to install a driveshaft. I'm running an LSA motor (supercharged) with a 6L90e transmission and a Ford 9" rear end with Truetrac. I'll likely have around 700HP. What are the advantages of steel/aluminum and who should I use? I'd appreciate any tips you might have.
      1969 Camaro - LSA motor, 6L90 transmission, TCI front subframe, TCI torque arm rear suspension, Ford 9" rearend
      Apr 2012
      Woodstock, IL
      Steel is fine for just about anything. Aluminum is lighter but needs to be bigger than steel for the same strength which can limit exhaust clearance if it's a tight squeeze underneath.
      Chromoly is stronger than steel so it can be a smaller diameter too.
      -Dale
      SchwartzPerformance
      Sep 2010
      Santa Clara, CA
      If you do a search for "driveshaft" I suspect that you will find no shortage of opinions here.... I am leaning towards working with Mark Williams when the time comes, but I also believe Inland Empire is a sponsor here and has many good recommendations.
      Steve
      Apr 2010
      Pittsburgh, PA
      Funny thing I was just thinking about driveshaft and cant seem to find that thread from a few days ago about ready available driveshaft with cv joints at each end..
      72 buick skylark
      twin-turbo fuel injected buick 350..perhaps stroked to 370 in the works!
      Indiana
      I have driveshafts from Denny's on the Chevelle and El Camino. Never had a single issue with either one.
      http://www.dennysdriveshaft.com/
      Herb
      1966 Chevelle 509/T56Magnum
      1963 C10 454/4L80
      PHR CHP CHP youtube
      Feb 2006
      Tennessee
      Quote Originally Posted by Yelcamino View Post
      ^^^^Totally agree. Great service, support, and product at Denny's.
      66 Chevelle - LS-Leap
      LQ9 / T56 Complete - Phase 2 in process!!
      https://www.pro-touring.com/threads/...t-LS-Heap-quot
      SC&C, Kore3, Detroit Speed, BBS, Advanced Induction, TickPerf, Currie, Moser, Holley, Hellwig, Edelbrock LS-Kit, Mast, Wilwood, BP-Automotive, StopTech, Ridetech, Hotchkis, UMI, Energy Suspension, AAW, B&B Classic's, PPG, Aeromotive, Canton, C&R, Sparco, Ididit, Spectre, Bridgestone, DakotaDigital, Alpine, RockfordFosgate
      Dec 2010
      Fredericksburg, VA.
      I ordered a Strange drive shaft from Summit.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
