View Full Version : I need a custom driveshaft
terrydmorgan
06-04-2014, 07:50 AM
It's finally time to install a driveshaft. I'm running an LSA motor (supercharged) with a 6L90e transmission and a Ford 9" rear end with Truetrac. I'll likely have around 700HP. What are the advantages of steel/aluminum and who should I use? I'd appreciate any tips you might have.
Schwartz Performance
06-04-2014, 09:19 AM
Steel is fine for just about anything. Aluminum is lighter but needs to be bigger than steel for the same strength which can limit exhaust clearance if it's a tight squeeze underneath.
Chromoly is stronger than steel so it can be a smaller diameter too.
-Dale
sjaroslo
06-04-2014, 10:12 AM
If you do a search for "driveshaft" I suspect that you will find no shortage of opinions here.... I am leaning towards working with Mark Williams when the time comes, but I also believe Inland Empire is a sponsor here and has many good recommendations.
Nothingface5384
07-30-2014, 02:48 PM
Funny thing I was just thinking about driveshaft and cant seem to find that thread from a few days ago about ready available driveshaft with cv joints at each end..
Yelcamino
07-31-2014, 03:50 AM
I have driveshafts from Denny's on the Chevelle and El Camino. Never had a single issue with either one.
http://www.dennysdriveshaft.com/
analyte
07-31-2014, 06:37 PM
^^^^Totally agree. Great service, support, and product at Denny's.
TheJDMan
07-31-2014, 06:50 PM
I ordered a Strange drive shaft from Summit.
