    Results 1 to 11 of 11
      Apr 2010
      Pittsburgh, PA
      balancebar and linelock?
      is there anyway to use a hydroboost/balance bar and also a hurst roll control linelock? or any other way to lock fronts to do burnout?
      or are you forced to stick with a proportional valve when needing a linelock
      72 buick skylark
      twin-turbo fuel injected buick 350..perhaps stroked to 370 in the works!
      I see no reason why you can't install a line lock solenoid in line between the MC and the T for the front brakes.
      Jun 2006
      Katy,TX
      Many line locs esp the Hurst can actuall act as the T and even have a left over port for a pressure gauge.
      1978 Black Trans Am 455 Edelbrock heads [email protected] through mufflers on pump gas
      1981 Trans Am 400 stock type motor
      79 Camaro getting a 500" 695 hp IA2 Pontiac motor
      1965 GTO project car
      470ci/Chevy dual quad 409 604 HP 64 Impala SS project
      2004 Pulse Red GTO
      Apr 2010
      Pittsburgh, PA
      good deal, I didnt know much about balance bars except they replace the porp valve, so figured I'd ask
      72 buick skylark
      Quote Originally Posted by Nothingface5384 View Post
      Maybe I misunderstood your original post, but how are you planning on using a hydroboost with a balance bar? Generally balance bar set-ups are for manual brakes. But either way, you can do a line lock.
      Mar 2011
      Ca
      I have hydroboost and a line lock on my rear brakes, so far everything seems to be ok.
      Apr 2010
      Pittsburgh, PA
      http://www.lateral-g.net/forums/showthread.php4?t=36692
      72 buick skylark
      I am generally not a huge fan of over boosted braking systems, but that looks like an interesting set-up. It would be very easy to plumb a line lock with that set-up.
      Apr 2010
      Pittsburgh, PA
      i'm just thinking hydroboost due to twinturbos
      engine is getting built very soon, just will do breakin Na/Carb prior to EFI/TT install
      72 buick skylark
      Oregon
      Balance bars allow you to tune your brakes for optimal performance at one deceleration rate, typically 100% since that's the worst case scenario with respect to weight transfer. At anything less than threshold braking (100%), you will be under utilizing the rear brakes. Proportioning valves are a relatively simple approach to attempt to optimize a single master cylinder system for all deceleration rate stops from 0-100%, allowing increased rear brake at lower decel rates and less at higher rates as weight transfers from the rear to the front tires.
      Tobin
      KORE3
      It's what I does.
      Dec 2002
      MusicCity
      Fantastic point that most don't know about
      Tobin, you hit it right on the nailhead. It's the "kneepoint" in the pressure rise that you are referring to. For those that are in need of a simpler explanation, balance bars are dead linear in the pressure(s) applied to the front and rear brakes based upon simple input force (meaning you hit the brake pedal and leverages apply to two separate master cylinders based upon where you have the setting (of left MC to right MC). What is actually being discussed here is the hydraulic 'variable' nature of the typical knob / lever type of inline (and also the stock block style OEM) type of proportioning valves. Might this be a "smarter" system as such? My opinion is YES for most all reading this. The real answer is microprocessor controlled "smart braking four channel antilock", but that is still a ways off from an aftermarket musclecar perspective.
      Where the hydraulic proportioning valve has the distinct advantage over the balance bar setups is that the rear brakes are much more active under most typical PT / muscle car braking needs, BUT deeply taper off the pressure to the rear brakes once the "kneepoint" is achieved. Translated into the simplest base understanding (meaning REAL WORLD), you want as much rear brake as your particular build can tolerate (but not to the point of bringing the vehicle into a tailspin under very hard braking). Read this, along with the further StopTech link included:
      http://www.hydratechbraking.com/braketech2.html
      There IS a difference - Thank you for choosing Hydratech!
      Paul M. Clark
      Founder / Master Engineer
      Hydratech Braking Systems ®
