    Results 1 to 8 of 8
      madisonville,tn
      Door pannel clips 1969 camaro
      Having problems with the clips on door pannels popping back out. Have new inserts and clips? Standard door pannels. Any ideas?
      Dan
      1969 rs, bbc, tremec 600, 12 bolt, mini tubs, dse a-arms, springs, iforge wheels...
      Aug 2008
      Iowa
      are you using the wire clips? Those are nice if you remove the panels a bunch, but if you need something to stick, try the plastic threaded ones. They are usually only good once because when you pull them out it strips the threads, but the stick damn good.
      Oct 2012
      Brown Deer, Wi
      Check out a fastenal store. They have tons of different clips. May have something that could be more durable.
      Sep 2011
      Whitehall,Pa
      I use the heavy duty Velcro- works awesome and easy!
      Feb 2012
      Search Ebay for 3M Dual Lock.
      It is a "Velcro" but MUCH heavier duty. It is what they currently use to attach production door panels with.
      This is the build thread for my car
      https://www.pro-touring.com/threads/...-Beak-Job-quot
      Jonesboro, Arkansas
      Quote Originally Posted by hotrodneb View Post
      I used these to hold my aftermarket kick panels on. They hold really well, my only complaint is that the glue doesn't hold. If there was something that could be done about that, they would be great. I cleaned the surface to make sure there wasn't any residue or dust but they just don't hold on to the surface. It actually takes some force to separate them though..
      Carl Wilson
      Feb 2012
      A thin layer of high quality contact cement on both surfaces before applying the peel/stick solves that problem. I too had trouble getting them to stick to the paper backing of my door panel for example, but this solved that.
      Jonesboro, Arkansas
      Does the contact cement cause the glue on the velcro to give it up? I wondered if I should peel the double sided tape off and then glue the velcro to the metal.
      Carl Wilson
