    Page 2 of 2 FirstFirst 1 2
    Results 21 to 36 of 36
    Thread: ZR-1 Clutch
    1. #21
      I like that bell housing! Much more attractive than the burly (and heavy) QuickTime bell. Plus the QT bell hangs 2" below the pan in dry sump cars -- giving back one advantage of using dry sump.
      Next time for sure. Good information, thanks!
      John Parsons
    2. #22
      Beach Park IL
      Is the pump in the bellhousing already? That is cool, nice find and thanks for posting.
      Donny
    3. #23
      Mar 2015
      Yes I believe so, but its on its way so I don't have it yet. For magnum owners they might want to take a look at the parts diagram as you might need to spend just under $40 for some springs, pipe, plugs, ball etc to complete the pump system. I probably over ordered as some of it probably comes with the bellhousing, so it might be less? I will have to weed through my $40 bundle of extras to workout what is needed.
      For diy magnum and twin plate clutch set-up's unless you pay big dollars for a system from a vendor there is almost no real accurate info on custom fitouts. . The only deep LS bellhousings for typical set-ups are this one for the CTSV/Z28/ZL1, or the RM6038 from quicktime if you need a SFI Certified housing.
      For a clutch system with decent 850ftlb capability and OEM drivability I find you cant go past the oem C6 ZR1 Sachs unit combined with the Fidanza flywheel and the OEM ZR1 slave. Its a total spend of $1200 then add the CTSV/Z28/ZL1 bell for $300 delivered. That's all pretty good value in my book. So for under $4500 for a complete new system with the great magnum box your off and tearing up the track.
    4. #24
      May 2015
      The Tilton 60-6101 is not the proper application for a T-56 as it requires an adaptor plate to mount to. The 60-6105 would be the proper kit for a T-56 and comes with the adaptor plate for the front of the transmission. http://tiltonracing.com/product/6000...ease-bearings/
      Ken Scarbrough
      Customer Support
      office: 805.688.2353 x151 | fax: 805.688.2745
      Tilton Engineering, Inc. | 25 Easy Street / P.O. Box 1787 | Buellton, CA 93427 U.S.A
    5. #25
      Quote Originally Posted by Tilton Ken View Post
      Ken Scarbrough
      Customer Support
      Ken,
      Good to have you here. It's always nice to get "the tech" from the manufacturers!
      Instagram @projectgattago
      Dr. EFI
    6. #26
      May 2010
      kitchener,Ontario,Canada
      so being dumb and trying to not confuse myself with way to many part numbers and such . I have a 2007 Z06 427 with a T56 magnum and a quicktime bell housing . I also bought a ZR1 clutch . the one part i havent gotten yet was a flywheel ....someone please help me because now i am super lost lmao. what should i do ?
      Ryan Austin
      On twitter @raustinss
      On Instagram austinss70
    7. #27
      Quote Originally Posted by Ryan
      what should i do ?
      Katech makes an aluminum flywheel that works. Lingenfelter makes a steel one. Your choice, give one of them a call. I went Lingenfelter.
      John Parsons
    8. #28
      Jun 2015
      San Diego
      Quote Originally Posted by lxss350 View Post
      ACDelco 19206204
      GM Original Equipment Manual Transmission Clutch Housing CTSV
      Just a follow-up for those who are interested the LSX/A conversion flywheels. They are now in stock at Fidanza.
      The part number to order and weight information for the new aluminum flywheel is as follows:
      Fidanza part number - 198891 - LSX/A conversion to ZR1 twin disc
      PRODUCT weight is 11.70 lbs
      They are doing a 6 bolt + 9 bolt version as well as even a version using this oem c6 zr1 clutch for the new LT engine conversions. I don't know the part numbers as I have an 8 bolt LSX engine. The weight would be the same.
      Product photos:
      Attachment 109876
      does this mean they make a flywheel that would allow a zr1 clutch to work with a 8bolt lsx 454?
    9. #29
      Apr 2007
      Good info. That bellhousing is a bargain. Anyone with a T56 Magnum should be doing this swap because extra room in the bellhousing is always desirable.
      Only 1 problem I see is when using the t56 magnum with ctsv/zl1 bellhousing is the trans mount is out of level quite a few degrees, I have just test fit this same setup and have this problem now, don't see how I can clock the trans or ctsv bell counter clockwise to get my trans mount level. I have been told the t56 magnum top shifter plate is suppose to be clocked a few degrees towards driver, im my case the shifter plate is level and trans mount is clocked.
      Any suggestions on how to fix this short of changing everything out to a quicktime bell that is clockable
    10. #30
      May 2010
      They all have a lean to the passenger side as far as I know
      Ryan Austin
    11. #31
      Apr 2007
      I was told by tremec the top shifter plate leans to the drivers side and trans mount should be level?
    12. #32
      Is the engine level?
      Dr. EFI
    13. #33
      Sep 2016
      LA - Lower Alabama
      Quote Originally Posted by BEECHFRONT View Post
      My Magnum leans towards the driver side as well.
      Dude are you made of leprechauns? Cause that was awesome!
    14. #34
      Apr 2007
      Yes
    15. #35
      Beach Park IL
      98-02 F body bell housing has that angle built into it, apparently the CTSV bell does not.
      BEECH, you can run that but you will have to modify your crossmember - or - machine a wedge to go between the mount and the tail shaft. I had a similar situation with a T5 with a 3rd gen bell and a S10 tailshaft housing, built the angle onto the crossmember and drove it 30000 miles without issue.
      Donny
    16. #36
      Apr 2007
      Thanks dontlift.
