    Page 1 of 6 1 2 3 4 5 6 LastLast
    Results 1 to 20 of 115
      Holley EFI tuning and wiring
      Hello Everyone,
      I think all of you know me by now as I have been a part of this great community since the early days.
      Recently I have begun offering remote Holley EFI tuning services. This is something that I have been doing on the side, but am now expanding into a full-time operation. Unlike most tuner that focus on making a hero number on the dyno, my tuning focuses on enhanced drivability. This is something that a lot of tuners don't take the time to do, because it can be tedious and time consuming. However, there is nothing more important in a tune than having a solid idle and good driving manners.
      I have been playing with various EFI systems since the early 1990s, when I installed an analog Holley EFI system on my GTO around 1991. I have attended all three tiers of the Holley EFI training and am well versed in all Holley systems. I have tuned Sniper, Terminator, Terminator X, HP and Dominators.
      If you are considering converting any carbureted engines to EFI, or considering a Holley system for your LS, you can enlist my services before making the purchase decision. I can make recommendations and also offer wiring suggestions, which will make your installation reliable and smooth.
      I am also moving to the Kansas City area in about a week and will be offering full car and EFI wiring services. This will be done as a mobile service, with me coming to you.
      If you have any questions, please post them here, or send me a PM.
      Aug 2012
      Peoria, AZ
      I've used not only Andrew's expert wiring advice during my Holley Terminator install but also his tuning service to get it dialed in perfectly. To be honest, it ran pretty good after the initial wizard setup but once Andrew and I worked through the details of the tune, it is flawless now. Andrew is very capable at reading data, listening to user input and using the info to dial in the tune.
      I wish him luck with his impending move and the ramping up of his services.
      Lance
      Oct 2018
      Phoenix, AZ
      I gotta give a shout to Andrew's prowess as a tuner and being a knowledgeable resource for Holley EFI. I have a Dominator in my built SBF and it has been running amazing with his help. I live in AZ so this has all been 100% remote. I was nervous about paying someone across the country to tune my expensive engine, but he has made great suggestions throughout the process and been very respectful of my time and comfort level. If you follow his instructions you will be rewarded with a safe, but happy running engine. And his instructions all concern driving so it's kinda hard to hate that.
      Fredericksburg, VA.
      Well I'm currently running an MSD Atomic EFI so I guess you can't help me much with that, but if I run across a NASCAR surplus Holley EFI I will be in touch guaranteed. Best of Luck with the tuning business! Too bad Lance moved from KC to AZ. I have to drive through KC every time we go home to visit family in KS and my brother currently lives in Lawrence so we are in the KC area pretty frequently. Al least with the Kansas Speedway there on I70 and SCCA based in Topeka at Heartland Raceway, you should have all sorts of autoX and track day events in easy driving distance.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Feb 2019
      Kankakee IL
      Andrew has successfully tuned the Sniper on my Cougar. I won't have any issues calling on him again.
      Tracey
      TuoCo, CA
      Andrew has been a huge help in getting my Terminator TBI/Hyperspark install running great. He's helped troubleshoot and get the tune dialed in. Well worth the price for sure. Once I get back on track, he'll be helping me live tune my idle.
      Andrew, I hope the move is smooth and everything you're looking for. If you ever find yourself out my way the first one is on me!
      Steve
      Check it Out Here
      Newbury Park, CA
      Congrats on the new adventure(s)!
      Thanks Carl!
      And thank you for the amazing testimonials!
      May 2020
      Hi Andrew
      So what’s your take on running a new never run terminator on a fresh engine build?
      Hydro roller cam
      Quote Originally Posted by CTK View Post
      Hi Andrew
      Hydro roller cam
      It depends on ones level of confidence in their wiring and making an initial tune. There is also nothing wrong with stabbing a trusty HEI distributor and a known good carburetor, and using that for initial break in.
      Oct 2018
      Phoenix, AZ
      Hi Andrew
      Hydro roller cam
      I did exactly this with a Dominator just before I started working with Andrew. Everything went fine, but I wish I had already been working with him because he would have helped me catch some things in the base map that would have made the first start even smoother. If you lack any confidence at all in your wiring or initial programming then you definitely want him hired before the first start.
      I can't say enough about Andrew's tuning and advice in general! I went from a barely driveable tricked out 950HP to a Holley Terminator TBI and Andrew helped every step of the way!
      From his advice on designing the fuel system to putting me in touch with Carl at vaporworx, his advice and tuning has truly been invaluable!
      I put off going to EFI because I "knew" carbs and how to adjust timing etc, but I'm here to say I should have made the switch 10 years ago!
      Andrew has truly transformed the car from a tempermental rowdy (fuel bowling) monster to a driveable, enjoyable car with predictable manners that still rips to redline and starts reliably (hot or cold) without issue!
      Enlisting his services with your tuning or wiring needs will be the best investment you've ever made in your car!
      SMSgt Ty Ingle, USAF
      "CF71" - Freedom Bird
      Oct 2011
      Congrats Andrew and best of luck to you!!
      Quote Originally Posted by OLDFLM View Post
      A big part of the success here was Carl from VaporWorx and also John Parsons. John did the heavy lifting with installing the new fuel system and installing and wiring the Holley Terminator EFI.
      Ty's engine doesn't make a lot of vacuum when idling, so it was a bit of extra work to rescale the load and RPM axes to get more resolution in the areas of the fuel and timing maps where this engine actually runs. I think Ty has more miles on this car since the recent round of upgrades and the tune than he had in the past 10 years since the car has been "professionally built."
      Thank you Sir!
      Quote Originally Posted by Andrew
      Ty's car was quite the mess when I first started working on it last summer. Wiring, plumbing, AC, etc. Lots of incomplete and incompetent work. It's vastly improved now with a custom 2.5" SS exhaust and X-pipe, working AC, power steering, working gauges, fans, torque converter, vaporworx fuel delivery, and now the Holley EFI. The car fired up on the first try after the installation, and after we figured out the secondaries were cracked at idle, and that we had a bad fuel pump relay, I handed the tune over to Andrew. The car always had good "bones", and now it's got some muscle to go with them.
      Andrew has improved the fuel economy from 6.5 mpg to nearly 10 over the past few weeks. The car just begs to be driven now, and Ty is obliging it!
      John Parsons
      Nov 2009
      Austin Texas
      Andrew has been tuning my LSA setup in my 69. Its driveability is phenomenal and its running great. I would highly recommend him.
      Oct 2015
      Andrew tuned the Terminator X Max system on my 70 GTO to perfection, I have been fortunate enough to live close to him so he actually came to my house for the initial tune as well as recently doing some online "team viewer" tuning to fix an idle issue I had. I would never have imagined that my 500+rwhp hot rod would run and drive so nice and civil. Andrew has also tuned some of my friends cars here in Birmingham with the same satisfying results. I HIGHLY recommend his tuning services, he is not only extremely skilled but an awesome person to know and hang out with (did I mention he likes to eat some good food as well). See you at LS Fest Andrew and all the best to you and Karen on the move to Kansas.
      Chicago
      Hi Andrew, I will be calling you hopefully soon as I have the new Holley Terminator X going in the 70 Camaro.
      marty-mj
      Shoot me a PM when you're ready and I'll send my number. Looking forward to working with you.
      Houston, TX
      Good luck on your move and the new adventure Andrew.
      Tu Ho
      Firebird V2-LS swap
