    Page 2 of 2 FirstFirst 1 2
    Results 21 to 37 of 37
    1. #21
      Aug 2011
      North Platte,NE
      Can I get the watts mechanism separately?
    2. #22
      Sep 2008
      Sacramento, CA
      Quote Originally Posted by 72BBSwinger View Post
      We offer a universal Watts link kit. You can find it at the link below. The mechanism is not available by itself.
      https://www.cachassisworks.com/p-318...max-width.aspx
      Carl Ogren - Sales and Tech
      Email us to get your Chassisworks/TCP Equipped vehicle featured on Facebook!
      Chris Alston's Chassisworks - Phone: 888.388.0297 ext 247
      Chassisworks - TCP - Varishock - Component Drive Systems - KP Components
    3. #23
      Apr 2010
      Pittsburgh, PA
      What length torque arm would you recommend for a 104 wheelbase ford maverick
      Very similar to an early mustang..but different enough to beed longer LCA and reworkibg of everything
      This universal kit may be the ticket
      May do the same for my 72 skylark(112'wb) if speedtech cant supply a part list that ive been persistant about..
      72 buick skylark
    4. #24
      Nov 2018
      Quote Originally Posted by Carl @ Chassisworks View Post
      Chassisworks is excited to announce the latest addition to our complete line of Pro-Touring suspension systems - The Chassisworks Torque Arm g-Link.
      Click To Enlarge
      A skillfully engineered system with multiple geometry and setting adjustments for tuning and refinement, Chassisworks' Torque Arm g-Link Suspension directly replaces the OEM leaf springs and shocks for significant performance increases in cornering ability, throttle response, and braking stability. System packages include our unique fabricated torque arm, g-Link tubular-steel pivotball lower arms, a Watts link or panhard bar lateral locator, VariShock billet-aluminum coil-overs, weld-on frame brackets, and optional billet-arm splined-end anti-roll bar.
      The torque arm requires a Ford 9” center section and Chassisworks Subframe g-Connector chassis stiffening system or universal-fit tubular crossmember. Weld-on lower axle brackets are included with bolt-on brackets for GM multi-leaf spring pads as an available option. Applications include ’67-81 Camaro/Firebird and ’62-72 Chevy II/Nova with OEM wheel tubs or mini-tub conversions. There are also components available for custom-fit applications.
      Click Here to view available options and configure a system for your vehicle or call direct to 800-722-2269.
      For an extremely detailed and thorough review of all aspects of this system, I encourage you to download the 20 page Product Data Sheet by Clicking Here.
      Click To Enlarge
      So I have a 1968 Galaxie 500 fastback would this fit on the frame if I changed the rear axle
    5. #25
      Quote Originally Posted by DudeTheCarMan View Post
      Unfortunately, Carl is no longer at Chassisworks. Your best bet is to give them a call and ask.
    6. #26
      May 2016
      Sacramento, CA
      Actually , as long as you use a 9" style rear end, . we have kits that will weld into any car.
      Mike Weddle
      Senior Sales Technician
      800-722-2269, ext 250
      [email protected]
    7. #27
      Nov 2018
      what about front end its got an okay set but its just this stamped piece I want something a little better for her.
    8. #28
      May 2016
      Sacramento, CA
      a new front for the Galaxie ?.. if you can weld, I can get you started.. http://www.cachassisworks.com/p-3807...clearance.aspx
      Mike Weddle
      [email protected]
    9. #29
      May 2019
      Pensacola,Fl.
      I know this is a old thread, but I seriously considered it.....Biggest draw back is no way to snake the exhaust piping thru it..
      Not with Air Springs anyway.
    10. #30
      Feb 2020
      Has anyone actually installed this product? I can't find anyone who has
    11. #31
      May 2014
      Stanislaus County Ca.
      Quote Originally Posted by SPG View Post
      I was looking at it myself, looks real nice, I like the front
      bushing/bearing on the torque arm and the watts link setup too!
      But shied away and went with the Speedtech since I never actually saw one in person at races or anyone on the forums.
    12. #32
      Feb 2017
      Quote Originally Posted by ilikeike View Post
      Here's a picture of mine (in a '73 Camaro). Exhaust is indeed tight and it's currently only 2" since I wanted something fast. I'm planning on eventually putting in a full 3" with an H-pipe and over the axle tailpipes.
    13. #33
      Feb 2020
      Quote Originally Posted by Bobo73 View Post
      Hello, I bought a torque arm from chassisworks as well and I am hoping you can give me a lot of pictures and measurements of your set up so I can verify with what I have. Right now my torque arm extends 3" past where it's meant to and I am pretty sure some part somewhere I have was not made to spec
      I am hoping you can reach out to me through private message so we can talk about this further, any help would be greatly appreciated since chassisworks is claiming I'm doing something wrong.
    14. #34
      Mar 2021
      Indy
      If you have a question call Chassisworks directly. They have a tech team which is very good.
    15. #35
      Feb 2020
      Quote Originally Posted by NCSU68 View Post
      I wish that was the case, their tech support is being incredibly unhelpful and refusing to acknowledge something is wrong. They keep blaming my issue on variations of the front subframe even though the front subframe doesn't change the install process of this kit.
      My components are 3" off, thats not a variation issue, something was grossly miscalculated or I was given the wrong part.
    16. #36
      Mar 2021
      Indy
      Try calling Carl Robinson at ChassisWorks 916 290 7612. He has helped me and fix several issues. I hope he can help you. Please post an update.
    17. #37
      Feb 2020
      Carl is the person telling me my issue is the differences in subframe causing problems sadly.
