    Page 11 of 13 FirstFirst ... 6 7 8 9 10 11 12 13 LastLast
    Results 201 to 220 of 247
    1. #201
      Sep 2012
      Hemihunter
      More rear suspension pics.
    2. #202
      Sep 2012
      Hemihunter
      I did some plumbing on the engine. Just waiting for my fuel lines to come in. Also installed the new custom gas cap.
    3. #203
      Jan 2011
      Jefferson City, MO
      Looking badass!
    4. #204
      Sep 2012
      Hemihunter
      Installed the exhaust system today and finally got the motor started. I bought it in 2005 so its been a long wait. Had a little hiccup with a pinhole in the oil pan weld. Had to pull the header and re-weld. Easy fix! Engine sounds Awesum! Also did some more wiring and plumbing on the car.
    5. #205
      Sep 2012
      Hemihunter
      Exhaust is on just waiting to install the 4" tips.
    6. #206
      Sep 2012
      Hemihunter
      Got the new aluminum drive shaft installed
    7. #207
      Sep 2012
      Hemihunter
      Car should be ready to go to upholstery by the end of the month. Anyone know a good upholstery guy in northern ca? Here is a pic from the internet of the leather colors i have picked out. Two tone brown and black. Not using the pattern in the picture!
    8. #208
      Nov 2011
      If you ever think about it while you have your car up in the air on the lift, could you measure your axle housing from either flange to flange or mounting surface to mounting surface?
      Justin Hocking
      67 Mustang Coupe to Fastback swap
      TCI front and rear
      Detroit Mini Tub
      Future coyote
    9. #209
      Sep 2012
      Hemihunter
      WMS to WMS is 48 1/4. In order to make that axle width work you will have to remove the original frame rails and make new ones out of sq. stock and weld them in parallel to each other.
    10. #210
      Jan 2020
      UT
      Impressive work there! That blacked out exhaust section makes everything look super clean!
    11. #211
      Nov 2011
      Quote Originally Posted by All4rocks View Post
      thank you SO MUCH! I have a TCI 3 link rear setup, and a Detroit mini tub kit that narrows the framerails. I also modified my 3 link by moving the link arms to inside the framerails. I LOVE how yours looks with the deep dish wheels, it is the exact stance im going for.
      Justin Hocking
      TCI front and rear
      Detroit Mini Tub
      Future coyote
    12. #212
      Dec 2018
      you should look up DJ Designs in Hayward, CA. I have an appointment to drop my car of to him 3/9 and that took my months to get, so, he is definitely busy. He is the best in NorCal though.
    13. #213
      Sep 2012
      Hemihunter
      No problem Justin. Sounds like you are going to have a sweet ride! Picture of your car?
    14. #214
      Sep 2012
      Hemihunter
      New steering wheel showed up today. I ordered it in a brushed aluminum finish so should go nicely with the brush panels on dash.
    15. #215
      Nov 2011
      i'll try to post one soon. don't have any pix on this computer
      Justin Hocking
      TCI front and rear
      Detroit Mini Tub
      Future coyote
    16. #216
      Sep 2012
      Hemihunter
      Got the doors and fenders fitted correctly and all the glass in. Power windows work now. air ride ride has 1 leak in one of the valves that i need to fix so i can play with ride height.
    17. #217
      Chicago
      The car looks spectacular and I can't wait to see more.
      marty-mj
    18. #218
      Sep 2012
      Thanks Syborg. As soon as i get the hood installed it should look like a real car again. Second guessing these wheels as i purchased them 7 years ago. Thinking of something that has a little more "pop" to them.
    19. #219
      Oct 2015
      Looks great. Beautiful car. With the glass scoops and such they are a bolt on and thus can be painted underneath. With the steel how do you paint inside and keep water from getting trapped and causing issues?
    20. #220
      Sep 2012
      Hemihunter
      Quote Originally Posted by Alwhite00 View Post
      Good question as i addressed these issues with the painter before i built the scoops. The inside of the metal was treated before i welded them on. He also painted inside them as best as he could. He advised me to never wash the car with water as he has a system of cleaning that will help keep scratches and swirls to a minimum. I did make little soft rubber plugs that fit into the scoops should i have to hose it down to get it clean.
