    Results 1 to 9 of 9
      Jan 2014
      Austin, TX
      How to wire a 110v home bluetooth speaker into a car??
      Ok, hear me out.... I want to install a Marshall Stockwell wireless bluetooth speaker in my 1972 C20 Suburban. A company called "Cool & Vintage" restores vintage Land Rovers, and uses Marshall bluetooth speakers, in a custom center console, wired into the cars electrical system somehow. I'm looking to copy their idea for a simple and classic looking installation without installing a full audio system since my truck is all original dash, door panels, etc.
      So what's the easiest, safest way to power a 110v AC appliance off the car's 12v DC power supply.
      Thanks for the help!
      1972 C20 Suburban
      1964 Corvette Coupe
      Oct 2011
      AC to dc converter
      Nov 2011
      Wylie, Texas
      This speaker uses an AC adapter to get 15V/1.8A power to the speaker. Instead of using this adapter I would connect the speaker to the car battery using a buck boost controller like this one.
      Jan 2014
      Austin, TX
      AC to dc converter
      Understood....would the proper method of wiring this be to use a relay in the power supply coming from the battery to the inverter and then use a keyed 12v source to power the relay, that way the inverter, and thus the speaker would only see power when the car was running?
      - - - Updated - - -
      Quote Originally Posted by blitzer454 View Post
      interesting....so how would you wire this?
      1972 C20 Suburban
      1964 Corvette Coupe
      Apr 2010
      Jersey Shore
      I also vote for the booster... It has a 12v positive and ground input, and a variable DC voltage output. Just cut the wall plug off and wire the variable out (15V) to the power input of the speaker.
      -Chris
      '69 Corvette
      '55 Chevy Hardtop
      AutoWorks Middletown, NJ
      Nov 2011
      Wylie, Texas
      Run a 5 amp fused 18 gauge wire from an accessory switched source to the input side of the buck boost board. Use the same wire gauge for the ground wire and connect it from a good chassis ground to the input side of the board. For the output side of the board I would buy the same barrel plug that is used on the AC adapter or if you don't plan on ever using the AC adapter you could just cut off that barrel plug and use that wire and plug instead. Then turn on the ignition key and adjust the output of the buck boost board to 15V and then you're ready to plug into the speaker power jack.
      Jan 2014
      Austin, TX
      I appreciate the info guys. So if Im understanding you correctly, the speaker actually needs to see 15V/1.8A power to operate. In the "at home" application, the AC adapter that is integral to the power cord is converting the 110V AC coming out of the wall to 15V DC for the speaker to use? But in my instance, all I need to do is use the buck boost board to convert, or boost, the car's 12v DC to 15V DC in order for the speaker to work off the car's electrical system?
      Again, thanks very much for the help!
      1972 C20 Suburban
      1964 Corvette Coupe
      Apr 2010
      Jersey Shore
      Quote Originally Posted by FLYNAVY53 View Post
      Yep! Most ac convertors actually list input/output voltage
      -Chris
      '69 Corvette
      '55 Chevy Hardtop
      Jan 2014
      Austin, TX
      ok perfect, thanks Chris!
      1972 C20 Suburban
      1964 Corvette Coupe
