Results 1 to 16 of 16
Thread: 1970 Chevelle ground up build.
08-23-2022 #1Registered User
- Aug 2022
- 11
Purchased a barely running 1970 Chevelle a few months ago .I'm in the process of restoring from the frame up. Will post progress as I go.
08-23-2022 #2Registered User- Join Date
- Aug 2022
- 11
Smooth firewall..
Filled in holes and welded in 14 gauge smooth firewall panel. Skimcoated and rough block sanding.
08-23-2022 #3Registered User- Join Date
- Aug 2022
- 11
Smooth firewall cont..Fabbed and cerakoted custom clutch master cylinder fluid res
[ATTACH=CONFIG]20165
Made driver side panel to smooth out firewall. Custom fabricated clutch master cylinder fluid reservoir. Mounted on studs welded from inside.
08-23-2022 #4Registered User- Join Date
- Aug 2022
- 11
Fluid tanks.
Fabbed up mirror image supercharger coolant reservoir and power steering tanks. TIG WELDED, internally baffled. Cerakoted with carbon grey and black. 3 liter capacity.
08-23-2022 #5Registered User- Join Date
- Aug 2022
- 11
Cerakote
Disassembled, media blasted and Cerakoted various parts. Used Cerakote "E series" in Carbon grey and Blackout.
08-24-2022 #6Registered User- Join Date
- Aug 2022
- 11
Frame boxing and strengthening.
Installed a Hellwig FX frame boxing kit. Added some gussets In a few spots to add rigidity. Repairs some crappy oil pan and header clearancing done by the PO.
08-24-2022 #7
