    Results 1 to 17 of 17
      Aug 2015
      NJ
      Your ride is done - how do maintain your showcar finish?
      Specifically I am curious who is using wax vs the new ceramic coatings available today?
      A high quality Carnuba wax will give off a superior shine
      A Ceramic coat will make the car more glossy and glassy
      Do you guys have a preference of one over the other?
      Is it frowned upon to have that glassy look over the Carnuba when being judged sat a car show?
      Getting ready for a big car show at the end of the month and just wondering what ya all have to say from past experience.
      If you have that winning combo and are willing to share, please feel free to post
      Thanks in sdvance
      '68 Chevy Camaro Pro-tour ~ project DMENTD
      '57 Chevy 3100 Pro-tour pickup ~ under construction
      Neither wax nor ceramic for me. Paint needs to breathe for longevity. Good luck if you need a touch up or repair over one of the “quality” ceramic coatings.
      Adams detail spray or something similar should be all that is needed over a quality paint job imho. Kevin won two awards at Goodguys using just Adams on the two Camaros I painted for him.
      Aug 2015
      NJ
      Reason I was asking is my car was never washed until I blew my water pump back plate gasket. Even though I used the 2 bucket was method, I scratched the paint from washing. The car will need to be re polished. Also I neglected to say that this is a driver and not a trailer queen.
      I did a lot of research and both wax and, from what I've read, ceramic coatings can be easily stripped chemically or with polishing.
      I know you have an extensive background and I do respect your comments so could you please explain in a little more detail please. I feel like I am missing something major here.
      I am also aware paint have to breathe but one thing always perplexed me about that - how do they get away with the new clear film they are applying to new cars? Wouldn't that be the worst thing you could do to paint or even worse a wrap?
      There is a long discussion on the SPI forum about how hard some ceramic coatings are to remove. Generally the quality ones are tough to remove and make repainting expensive. I trust the guys on that forum, they are not trying to sell me anything and do it for a living.
      I would never apply a clear film over paint.
      My experience is not extensive, I am just relating what I have learned.
      To be honest some better care with how you wash your car and Adams detail spray is my advice to you. Black is a beeotch and it takes a lot of careful attention when washing. Materials and methods.
      My painter guy would say at least 90 days for new paint before waxing. Solvents in the paint need time to cure.
      I like a good wax to make it shiny and also makes it easier to clean after a drive. Lot's of bugs up here in MN. I use the detailer products if the truck is very clean. It may be just be me but it seems like the detailer products seem to attract dust more than just a good wax.
      I've seen the ceramic products in the parts store but never purchased them.
      Either way if you have light swirl marks in the paint it may need a light compounding and then polish. After that a good wax? Wax won't take out swirl marks.
      Aug 2015
      NJ
      I totally agree with you on the car washing. I also have a black truck and always get out the foam cannon to get as much dirt off as possible beforehand and to get as much suds as I can on there afterwards before I bucket wash
      Couldn't do that with the Camaro because I was washing it after getting towed home between 12 and 1am.
      Now that I think about, I see where the coating could be a PITA. You would have to strip the entire car to fix one spot because you can't blend into a coating.
      Aug 2015
      NJ
      Quote Originally Posted by 79 Camaro View Post
      Definitely needs to be compounded. Could most likely get away with a finishing polish.
      My car was painted 2 years ago
      Thread about ceramic coatings:
      http://www.spiuserforum.com/index.ph...96/#post-69702
      Oct 2014
      DFW, Texas
      Clay bar, polish with a DA and sealed with meguiers ultimate fast finish. Works for me.
      1976 Dodge D100 - Warlock
      2016 Subaru WRX - E30 Tune
      It's interesting about the post above and clay bar. When I was doing the body work on my C10 in my body shop guys shop he had a number of late model cars in for pre-summer clean up and after a good wash they started with a complete clay bar of the body. Every inch. Then compound, then polish. They let customer do the waxing.
      Oct 2014
      DFW, Texas
      Clay bar is a magical thing, but it is an abrasive, so you'll want to limit how often you do it and do some polishing after. The results are excellent if you've never done it before.
      Jonesboro, Arkansas
      My son and I use Chemical Guys products. Very nice products and work well. Also the procedure you wash is important. Chemical Guys have a “cyclone” piece that goes in the bottom of the bucket that helps separate the dirt from the water.
      Carl Wilson
      Aug 2015
      NJ
      Quote Originally Posted by GoodysGotaCuda View Post
      Clay bars are awesome! Like you said almost magical in a sense. They actually remove all the surface contaminants and make your paint smooth as glass. You can get them in different abrasives as well, but will not remove scratches.
      Aug 2015
      NJ
      Quote Originally Posted by minendrews68 View Post
      Great point! I always use grit guards in both buckets. If I even have to wash again, I will try the new method of one microfiber cloth per panel
      Aug 2015
      NJ
      Aug 2015
      I used a bunch of things...meguires, pinnacle, etc....The one i like the best is Zaino. Again, I rarely wash my car, just use the quick detailer, and the sealants, etc... Foam cannons, and clay bars are awesome. There are a ton of products out there, but if you keep it clean, and waxed and always use the leaf blower!...no worries.
      I give my Cougar a coat of Penetrol, twice a year, whether it needs it or not :-P
