    Page 18 of 20 FirstFirst ... 8 13 14 15 16 17 18 19 20 LastLast
    Results 341 to 360 of 394
    1. #341
      Jonesboro, Arkansas
      Quote Originally Posted by CamaroAJ View Post
      If you're using an iPhone to take the picture put the home button (or bottom of the phone if it doesn't have one) in the 3 o'clock position when taking pictures and that will correct your issue.
      He's right...., ask me how I know. Dude, you've seriously got some fabricating skills, congrats!
      Carl Wilson
    2. #342
      Nice job on the vent-A/C it looks great with that radio, it goes together well.
    3. #343
      Maybe I'm just being OCD... but wouldn't the radio look better if it were centered under the AC vent?
      It doesn't appear that you have room to move the vent to the right so the radio would need to move left an inch or so...
      LOVE this build! Keep doing what you're doing! One of my favorites in awhile!
      SMSgt Ty Ingle, USAF
      "CF71" - Freedom Bird
    4. #344
      Love what you are doing, keep up the great work! Love the work on the cluster.
    5. #345
      Dec 2014
      Country Flag: Australia
      Thanks everyone!
      Quote Originally Posted by OLDFLM View Post
      Oh yeah, I thought about that a lot before cutting anything. My OCD goes in overtime too. The thing is though the A/C vent in slightly off centre. It was just the way it needed to work. The stereo is centre. As will the switches and other things going under it.
    6. #346
      Oct 2011
      Wichita KS
      Amazing job fabricating and shrinking the size of the dash cluster! You are inspiring me to do something different in our 49F1.
    7. #347
      Dec 2014
      Quote Originally Posted by Widetrax View Post
      Much appreciated, Widetrax!
      This has taken quite a bit of time tinkering with. It's not finished, this is the mocked up and running state with just a power source attached. They will in the end just be plug and play with the Audi wiring harness and standard Audi controls. Now that I know it works, I can pull it apart and finish the welds and dress all the parts.
      I'm pretty sure I posted some time back how I modified the Audi wiper motor assembly and made it fit in place. This now has linkage set that I made to the calculations required for the correct angle and sweep. And by using the little tie rod ends, I can fine tune the resting position of each wiper arms individually.
      Changing the repro wiper arms from left hand drive to right hand drive was a pain. But they are done now. I think I'll paint them black though.
    8. #348
      Dec 2014
      This has taken me quite a few hours, to turn this, which is all of the body wiring from the donor S5.
      Into this
      just to get this. It is the wiring and components to operate the electric park brake calipers.
      And while I was at it, I continued and turned the rest, many hours later
      into this. Lots of spare OEM colour specific spares for when I start modifying the RS6 harness to suit the F1 cab.
    9. #349
      Minneapolis, MN
      Jan 2011
      Jefferson City, MO
      Holy crap! I'm glad it's you instead of me.
    11. #351
      Wow that first picture reminds me of one of my nightmares! Nice Work!
    12. #352
      Dec 2014
      Not wrong, that was pretty involved in getting all of that removed from the S5. It took me probably a day just in doing that whilst not trying to break anything as well as to label each plug. I've been at it here and there for a couple of weeks. But the end result should be well worth the effort when I need it all later.
    13. #353
      Feb 2014
      I tip my hat to ya Sir, I think my level of patience would have been tested to it limits right here.
    14. #354
      Dec 2014
      Thanks, Bob!
      I am making the most of this quarantine period. In between working at home, home-schooling the kids and house jobs, there's been plenty of truck time. It's all slow going but progress is progress.
      After attending to some rust repairs, I made some floor panels
      and a centre piece and that section is now done.
    15. #355
      Dec 2014
      I love this rivnut tool.
      The auto is temporary. So I have made the space around the shifter suitable to adapt the manual shifter later. I need to leave the auto in for now as I know the car was running before so will get to that point first, where the truck drives as an auto, and then work backwards.
    16. #356
      Dec 2014
      The rear section now welded in too.
    17. #357
      SF Bay Area
      Quote Originally Posted by Max Power View Post
      It's good, you say? I just checked, and it turns out it's not that expensive. I may have to pick on up, as I had one that I really wasn't very happy with.
      chunger
      '68 Ranchero 500
      '70 Cougar XR-7 Convertible
      '98 Mustang GT Convertible
    18. #358
      Dec 2014
      I can't complain about it at all. I've used it multiple times now and it works a treat. This is the set that I bought.
      https://www.ebay.com.au/itm/14340199...&s=ci&mail=sys
    19. #359
      Sep 2019
      Utah
      Quote Originally Posted by chunger View Post
      I love mine as well, we use a lot of riv-nuts at my work, and have found through painfull experience that if you put a dab of lock tight on the knurled bit before you install them they hold even better and we never have them spin free now (used to be a issue...) we also use mini 12v impacts to install the bolt though.
      My cougar project.
    20. #360
      Dec 2014
      Got the floor done along with the removable section for the shifter. Steering column is in with a centre support bearing. Peddle box is sorted and back to working on the seat so that I can then start working out the seat belts.
