Results 301 to 320 of 534
03-30-2016 #301Registered User
- Jan 2016
- 46
You could do a fiberglass front clip to save a ton of weight. You can even get a full glass cab if you want to go crazy.
03-31-2016 #302
Depends on the fibreglass, I've seen 'glass hoods that don't weight much less than a full steel hood. I may lighten the sheet metal, I'd love carbon. Munssey Speed makes some nice stuff. I wish someone would make a the later square hood, the early hood is better for performance, but I have a soft spot for the later brick design.
In other news, my adventure to Holley LS Fest is in print. Performance Improvements produces a magazine, they circulate about 36,000 of these. They are having a huge sale this week-end, stop in for a copy of the magazine and they also have some posters of the truck to give out.
03-31-2016 #303Registered User
- Apr 2011
- 164
Hey Bovey
What does your truck weigh and what is the weight distribution?
03-31-2016 #304
04-17-2016 #305Registered User
- Jan 2016
- 46
I'm going through brake calculations right now and referencing yours -- what was the reasoning behind the wilwood calipers up front? The stock calipers have a bigger piston area and thus greater clamping force. Also the Hawk HP+ pads have a coefficient of friction of .55 -- not .41 at 700 degrees... I'm getting a brake force of 2800 lb vs 1600 for the stock front calipers in this configuration with a 7:1 pedal ratio. My calculations can be seen in this spreadsheet.
04-17-2016 #306
Those are good questions, questions I don't really have answers for. But I will offer this.
1) I needed new callipers, so upgrading to Wilwood's D52 was easy.
2) The variance in numbers maybe because Ron accounts for actual not theoretical. I believe his numbers are based on tests he has done, or information someone has given him. Can't recall.
3) I was having huge heat problems stock calipers, going to aluminum helped.
4) I seem to recall the larger diameter of the stock caliper was a wash because they flexed under heavy braking. Add heat and thing get inconsistent.
I know Ron is crazy busy at the moment, but I'll shoot him a message and try to get him to chime in.
04-19-2016 #307Registered User
- Jan 2016
- 46
I was looking at Howe calipers because they have slightly larger pistons, but then caught this quote on their product page:
"For higher heat applications we recommend a steel outer half to reduce high temperature flexing that occurs in all aluminum calipers."
I guess this means that the manufacture an outer half made of steel to use with the aluminum portion of the caliper, but I couldn't find it on their website.
http://www.howeracing.com/p-7708-how...le-piston.aspx
For heat dissipation I'm looking at these cool heat sinks:
http://www.fourproducts.com/coolshim-technology.php
But at their price ($120 for two wheels) I might get creative and make my own. They look like a computer heatsink brazed to a metal shim.
How do you know when you have temp issues, does your brake fluid burn up or something?
04-19-2016 #308Registered User
- Dec 2015
- Ruhr-Area, NRW, Germany
- 313
