Results 321 to 329 of 329
Thread: '72 Duster "AERO DUSTER"
12-10-2024 #321Benjamin
Twin Dusters
12-18-2024 #322
- Jul 2006
- Chesapeake, VA
- 679
Super nice car. I think you'll do much better by having a car you can drive and only taking it down for relatively short periods of time.
Cars are meant to be driven.
John B
12-19-2024 #323Benjamin
Twin Dusters
04-26-2025 #324
Forgot to update over here so here is my last post from FABO:
Not a bunch of progress to report but I'm slowly moving some upgrades I did to the old Gold car to the new Yellow one. over the last two weekends I've gotten most of the BBP disc equipment pulled and am slowly cleaning it up and getting it ready to put on. These are mostly new parts that have just been sitting since I blew up the engine but they will work for now. I will also move the bigger swaybar that is on there but I need to make some new brackets.
I am changing to the standard length UBJs because the long ones won't work with my 17s so I had to borrow a tool kit from the local auto parts store as they were in there pretty solidly. I will work on getting my own socket or wrench so I can do these on my own next time. Also while taking stuff apart I noticed that my LBJs are shot, So I will need to get them. We will see what else I run into as I go. Ended up going with just a plain grey for the brackets and calipers because I have it and because they hopefully won't be on there too long. I am going to braided stainless lines when I install them.
Benjamin
Twin Dusters
04-26-2025 #325
Got new LBJs, and new stainless brake flex hose for the rear since I've seen the stock ones swell up and reduce pressure before. I also found some blue washed grade 8 bolts at my local hardware store so I got the last few pieces I need for my Adjustable strut rods.
I've unfortunately been having trouble getting the old LBJ's off the spindles without them on a car. My impact isn't strong enough and I can't hold it to get the torque to get them broken loose (I don't have a vise). I got them mostly cleaned up though, they had a ton of caked on dried grease and such:
I also pulled the springs, Hangers and rear from the Green Parts car and am cleaning some of the pieces up so I can drop the rear back down to a reasonable level. I've considered doing new adjustable hangers but I may want to do an offset one for more tire clearance if I do that. The only ones I have designed are these stock offset ones:
I was also able to pull it out of the garage and get the engine bay a little cleaned up for some of the stuff I need to do there. Even just mostly idling it around it is a beast of a car. I hope to have it out on the road running around soon.
Here is a quick video for you to enjoy from post wash:
Benjamin
Twin Dusters
04-30-2025 #326
Good news this time! My PB blaster drip protocol and a fresh battery for the impact got the LBJ bolts loose last night.
After that I finished getting them cleaned up then mixed up some of my chosen suspension pieces color to spray with my new detail gun. Small cans of this hammered silver finish are like $8-9 each but I got a quart for $16. I had heard mixed reports about how the hammered finish worked with being thinned but after some experimenting I ended up doing a very light coat, then immediately doing one heavy coat and the finish turned out great. Definitely need to work on my mixing process because I made a mess and ended up mixing way too much so I went ahead and painted my torsion bars, the one spring hanger I had cleaned up and the fender braces (not sure they will stay silver). I'll get some better pictures in the daylight later.
I'm mostly traveling for the next couple weeks for work so likely won't get much more done but glad I was able to get these done and let them cure.Benjamin
Twin Dusters
05-01-2025 #327
