    Results 41 to 60 of 80
    1. #41
      Sep 2020
      Fayetteville Tn
      About 15 years earlier I had tried to make subframe connectors that went through the floor. I never finished them and the car sat in the side yard for years with animals and the elements. This time around I decided to do my best at a Detroit Speed su frame connector look alike. If anyone has been paying any attention to my posts they will see two things about me. One is I am having a hard time posting photos in order and even right-side up!!! While the second thing is I like to make things myself.
    2. #42
      Sep 2020
      Fayetteville Tn
Size:  225.6 KBName:  20230909_171442.jpg
Size:  323.5 KBName:  20230909_171153.jpg
Size:  304.9 KBName:  20230909_170904.jpg
Size:  444.7 KBName:  20230909_132732.jpg
Size:  236.1 KBName:  20230909_133337.jpg
    3. #43
      Jan 2000
      Thousand Oaks California
      Nice build!
      Thanks for sharing!
      Larry Callahan
    4. #44
      We all love pictures, so keep them coming! Looks like some solid fabrication and nice parts too!
    5. #45
      Sep 2020
      Fayetteville Tn
Size:  216.8 KBI modified my trans tunnel for a t56. I just used a cheap stock type patch panel and some sheet metal as well as using most of the factory tunnel.
    6. #46
      Sep 2020
      Fayetteville Tn
Size:  920.4 KBName:  20231126_140009.jpg
Size:  346.1 KBName:  20231126_140037.jpg
Size:  208.8 KBI picked up this T56 on craigslist a couple year or so ago. It came out of a 96 Transam with a LT1. I am sticking with a small block and so this LT transmission was just what I was needing.
      - - - Updated - - -
      The guy I bought it from gave me the wrong bellhousing and no clutch fork. I have since sourced the correct ones that cost way more than any used clutch fork should cost.
      I thought the last photo showing the size difference between the Muncie 4 speed and the T56 really gives you an idea of how much more room this transmission takes up.
    7. #47
      Sep 2020
      Fayetteville Tn
      I was able to get a swayber I had modified and installed over the last few weeks. The rear suspension is nearly done. I just need to make a better middle link. I will be running tail pipes, so I had to make trunk cutouts and installed the bar over and in front of the axle so I had room.Name:  20250823_184058.jpg
Size:  319.4 KBName:  20250824_191050.jpg
Size:  293.0 KBName:  20250823_155038.jpg
Size:  396.0 KBName:  20250823_155041.jpg
Size:  512.0 KBName:  20250823_141440.jpg
Size:  486.7 KBName:  20250809_100726.jpg
Size:  271.7 KBName:  20250802_125250.jpg
Size:  241.6 KBName:  20250802_122814.jpg
Size:  205.4 KBName:  20250802_113746.jpg
    8. #48
      Sep 2020
      Fayetteville Tn
Size:  357.2 KBName:  20250830_115931.jpg
Size:  112.0 KBName:  20250830_115455.jpg
Size:  135.0 KBName:  20250830_112526.jpg
Size:  168.5 KBName:  20250830_112709.jpg
Size:  204.6 KBName:  20250830_112854.jpg
Size:  292.8 KBName:  20250830_112015.jpg
Size:  141.9 KBName:  20250824_191021.jpg
Size:  358.8 KBName:  20250824_185111.jpg
    9. #49
      Sep 2020
      Fayetteville Tn
Size:  215.5 KBName:  20250901_101549.jpg
Size:  174.0 KBName:  20250901_095633.jpg
Size:  360.0 KBName:  20250901_094319.jpg
Size:  260.6 KBName:  20250830_142906.jpg
Size:  231.7 KBName:  20250830_135525.jpg
Size:  134.1 KBName:  20250830_135517.jpg
Size:  202.4 KBName:  20250830_134008.jpg
Size:  175.5 KBName:  20250830_135040.jpg
Size:  300.2 KBName:  20250901_095709.jpg
    10. #50
      Sep 2020
      Fayetteville Tn
Size:  265.8 KBName:  20251109_172227.jpg
Size:  305.9 KBName:  20251109_172319.jpg
      - - - Updated - - -
Size:  332.9 KBName:  20251109_172034.jpg
    11. #51
      Sep 2020
      Fayetteville Tn
      I have been busy working on the car over the last few months and haven't posted any of the work yet. The project has come along well though.
    12. #52
      Sep 2020
      Fayetteville Tn
Size:  263.8 KBName:  20251109_172034.jpg
Size:  331.4 KBName:  20250928_132645.jpg
    13. #53
      Sep 2020
      Fayetteville Tn
Size:  443.0 KBName:  20260125_130617.jpg
Size:  316.1 KBName:  20260125_130615.jpg
Size:  355.5 KBName:  20260124_164553.jpg
Size:  242.2 KBName:  20260124_162353.jpg
    14. #54
      Sep 2020
      Fayetteville Tn
Size:  470.8 KBName:  20260125_152624.jpg
Size:  426.9 KBName:  20260125_152640.jpg
Size:  467.6 KBName:  20260131_143645.jpg
Size:  274.0 KBName:  20260131_183842.jpg
Size:  220.8 KBName:  20260131_192249.jpg
Size:  95.4 KBName:  20260131_153246.jpg
Size:  360.5 KBName:  20260201_113535.jpg
    15. #55
      Sep 2020
      Fayetteville Tn
      I had the rear seat covers in a box from the supplier for over three years. The crease I hope will come out with some warm summer days
    16. #56
      Sep 2020
      Fayetteville Tn
Size:  327.5 KBName:  20260208_101306.jpg
Size:  196.8 KBName:  20260208_101330.jpg
Size:  223.3 KBName:  20260208_101338.jpg
Size:  195.9 KBName:  20260208_102031.jpg
    17. #57
      Sep 2020
      Fayetteville Tn
      I had to cut into the seat frames. I spliced in some steel where needed and did some pretty poor welds to tie some of the frame together just enough to still spring and move.
    18. #58
      Sep 2020
      Fayetteville Tn
    19. #59
      Sep 2020
      Fayetteville Tn
      I bought a hog ring kit on Amazon and batting from the fabric store. Once I had the stuff to do the job I spent some time at YouTube University and then jumped into getting the rear seats done.
    20. #60
      Sep 2020
      Fayetteville Tn
Size:  308.2 KBName:  20260131_171938.jpg
      - - - Updated - - -
      One thing that stopped my progress was this fabric covered wire needed to help support the hog rings in the fabric and not pull through.
