Results 1 to 20 of 22
06-23-2013 #1
- Sep 2010
- 12
Anyone have Pinto/Mustang II experience???
So I'm about ready to start modifying my recently purchased 71,855 mile one owner grandma 1976 Pinto wagon.
I'm looking for budget suspension upgrade suggestions. The front end, shocks, sway bars, steering etc... is a little tired. I want to lower it a couple of inches and go with 17 or 18" black center/polished lip wheels. Engine/trans I really want a 3.5 Ecoboost from a late model truck with a world class t-5 Ford Motorsports guys tell me this is reasonable.
Anyhow, back to suspension. I want to put a budget suspension package together and get some wheels on her. I'm thinking some expensive tubular a-arms such as these: http://www.ebay.com/itm/Ford-Mustang...54d599&vxp=mtr eliminating the strut rods, a shorter heavier front spring and or dropped spindles (do these effect bump steer?) just want to do lowering blocks and shocks in the rear for now. Also thinking about using 11" Granda rotors and GM calipers in the front for a budget brake upgrade and to switch to 5 on 4.5" pattern. Not sure on the rear end yet either. I have an Explorer disk brake 3.73 posi rear setting at the shop but if I shorten the long side and use 2 short side axles the pinion will still be offset 2" or so and the rear will be slightly shorter than the stock pinto. I can get an 8" out of a Maverick for $50 but gears and posi/lockers are big $$$ compared to a 9" or used 8.8 parts.
Any help in the right or away from the wrong direction is much appreciated.
