      Dash Plug Wiring Diagram 68 camaro
      The only two wires I need to get are the RT and LFT turn signal wires that come from the Dash Plug. I found the dash plug but dont know which wires are for the turn signals in the cluster.
      Does anyone have a layout of a DASH PLUG WIRING DIAGRAM for a 68 Camaro?
      Thanks in advance!
      Mark
      Melbourne, FL
      Here's a link to the pin out for a 68 Firebird. It should be the same. Look at engine #1 & #2. Hope this helps.
      http://thefirstgensite.com/html/68wirindex.html
      67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
      Honest dad that 455 on the side of the block is a serial number
      Nov 2010
      Elizabeth,CO
      I have the diagram if havent resolved your issue.
      Kevin
