    Results 1 to 11 of 11
      May 2013
      1966 Chevelle wheel choice...
      I've read so much conflicting information over the past few weeks about what fits this car it's making my head spin.
      The car is a 1966 Malibu, original 10 bolt, no modifications. I know the 66-7 are different than the earlier and later cars.
      I've ordered the SC&C Performance AFX package, placing C5/6 Vette brake order with Kore3 tomorrow. My 15x7 rally wheels won't work with that so I've been shopping and researching. Loads of advice and many conflicting reports. Lots of info about cars with later (wider) 12 bolt rears.
      Im just trying to find out if any/all of these will fit:
      Front will be 18x8, 0 offset regardless.
      Rear: wanted Boss 338 18x9.5 - only available in -4 offset (5.09 backspace) but many say it won't fit. I've seen pictures on this forum of a yellow stock 67 4 door running them, but many say it won't work.
      I've found American Racing VN805 Vintage Boulevard in the following sizes:
      18x9 with 30 offset (6.2 inch bs)
      18x9.5 with 0 offset (5.25 inch bs)
      I'd love to put 9.5" wide rears with 275/40 tires. Don't want to get wrong size though and the 9" would be tolerable. Really don't want to but I may just go with the 8" to be safe.
      Thanks for any help. This forum has been invaluable in planning my fairly mild PT dream car.
      Oct 2012
      FYI, the Ridler 695 is similar to the boss 338 and comes in a 5.5" backspace on the 9.5" rim. Just in case the extra .5" helps you out.
      May 2013
      I'm looking at the Ridler 695 as well, thanks.
      Since there doesn't seem to be many people who know what works with my set up, does anyone have a suggestion for a wheel measuring tool? I have seen them on TV but haven't used one myself. Any suggestions? I hate to pay much for one since I'll likely only use it once to make sure what I order will fit.
      Thanks.
      Mar 2012
      I had these 338 on mine
      Now rushforths
      May 2013
      Quote Originally Posted by MK69RSSS View Post
      Now rushforths
      Size? Backspace? Tire size?
      I appreciate the style suggestions but I really am looking for size information now so I can be sure whatever I get will fit the car.
      Thanks.
      May 2008
      South Jersey
      Quote Originally Posted by jamier2 View Post
      Thanks.
      Theres someone on here that bought one of those tools and rents it out. https://www.pro-touring.com/showthre...it-Tool-rental
      Nick
      '67 Chevelle 350/th350..... soon to be all aluminum 5.3
      '73 Chevelle 4.8/th350
      Oct 2010
      Mena, AR
      Alot of info here on this question about chevelles. These are mostly untubbed stock cars with many different choices. You can read over the excel spreadsheet here:
      http://www.chevelles.com/database/
      Or read through the whole thread here:
      http://www.chevelles.com/forums/showthread.php?t=33229
      Hopefully this will help you find what may work for your particular setup.
      Chris
      Chris
      1967 ElCamino
      2004 Chevy SSR (my sons)
      1951 Chevy pickup(my sons)
      1967 Elky https://www.pro-touring.com/showthre...587-Evil-Angel
      1951 truck https://www.pro-touring.com/threads/...3-year-old-son
      May 2013
      Quote Originally Posted by bmbrzmn101 View Post
      Chris
      I'd seen the database but couldn't find anything - maybe my computer didn't like it.
      I am looking through that thread now, thanks.
      I may attempt to find/borrow one of the real backspace/sizing tools that are floating out there.
      Oct 2010
      Mena, AR
      I've got a percy's tool for checking bs, will probably end up selling it. If interested lmk.
      Chris
      Chris
      1967 ElCamino
      Nov 2012
      San Diego
      I have a 66 with the spc, afx, kore 3 package and the later wider rear dimension diff (s60). front is 17x9, 5 bs, 255/45/17 rear is 17x9.5, 6bs, 285/40/17 the rear is very close to the outer fender lip but clears. If I did it again I would of order front 17x9 with no less than 5.5 up to 6bs, rear would stay the same. on your rear diff you are 1/2 inch per side shorter and I would order no less than 5.5 up to 6bs for your dimensions. hope this helps
      Mark
      May 2013
      Thanks, it's been very helpful.
      Mark (pro66), can you post or send me pics of your set up? I didn't think of fitting 9s up front.
      I finally got the database to work on my PC at work - wouldn't come up on my Mac at home for some reason. That is an amazing resource.
