Thread: Bowtie Overdrives TV kit 700r4
08-21-2005 #1
- Feb 2005
- 328
I have a 700r4 trans I am almost ready to install. However, the TV cable adjuster supplied looks completely cheezy compared to the TV Made EZ kit from Bowtie Overdrives. The only thing keeping me from purchasing their kit and tossing the spring adapter "system" that came with the trans is that it requires replacing an internal transmission part which I worry might void the warranty.
Has anyone used the Bowtie Overdrives' TV system with a 700r4 rebuilt by a different company?
I would mention the other company...but I might have to -
A) defend myself
B) trash them
C) confess that I should have purchased from Bowtie Overdrives in the first place.
09-19-2005 #2
- Aug 2004
- Washington State
- 88
You dont want to know what I think of Bow Tie...... True their TV cables are good but no better than Lokar. If you have one of their 700R4's or anyones for that manner dont hit it with to much power as they cant take it. There is no such thing as a High Horsepower 700R4. If you want to have fun and hit a GM OD auto get a 2004R. I killed 2 700R4s within 6 months both were covered by warrenty but I just didnt have it in me to go for 3. I went with a CPT. If you really talk to knowledgeable auto builders they all agree a 700R4 just cant be built to take any power or abuse. I was only hitting mine with about 400 hp. PM me if you want or need more info.
MikeLast edited by MStennes; 09-21-2005 at 04:58 PM. Reason: Bad grammer????
69 Camaro RS/SS convertable now being rebuilt again, out with the old in with more new
ETA, last time I'm tearing it down!!
09-21-2005 #3
Starting The Transformation
- Jun 2005
- 107
i had excellent luck with the bowtie overdrives tv cable, the internal part change is a matter of dropping the pan, as i recall they included a "spec" sheet for what the trans operating pressures "should" be when the cable is adjusted correctly. the simple yet effective cam linkage is critical to keeping the opperating pressures in check, having it improperly adjusted, WILL drasticly shorten the life of the allready mediocre trans. i would simply call the builder of the trans...and ask them if it will void the warranty. my only 700r4 is behind an efi ZZ4, ina 40 ford coupe, the car gets drag raced and cruised, and no problems after 2 years
09-22-2005 #4
