    Results 1 to 20 of 20
    Thread: 68 Max-G build
      Jul 2008
      68 Max-G build
      I have been building this for a few years and finally have a good jump on the project. Purchased as a “solid roller” after I found out my wife was pregnant. Katie called it my quarter life crisis. I started tearing it apart the day I got it home and I quickly found out how solid it wasn’t! I just wanted a neat car and liked the body style of 68 the best. Intention was a 427 big block, 4speed and some simple suspension upgrades so it didn’t twist in half, you know some simple stuff to get it going. I wanted something I could drive to the track, play a bit and tinker with to give me something to do other than work. Everything including paint will be done by me and the help of a few knowledgeable friends.
      As soon as I got it home I got the car torn apart and on a simple stand so I could wheel it around inside the 2 car garage. The more I dug the more I wish I hadn’t but knew I had to keep going. I was working on an old repair on a quarter panels and when I smacked it pretty good a fist sized glob of rotten bondo fell off the roll pan! I started searching websites on how to repair it when I came across this one and a couple others. Then… I found this dang website and the wheels pretty much fell off the cart. After Gunner was born I dint have much time to work on the car, so here I am 4 years later. I built a shop in the back yard (my Camaro cave) and finally have some time to play.
      Final plans are to ditch the LS1 in favor of a LS7 from Texas Speed or see what comes of the new GM engines. I don’t have a completion date so the final motor selection may be decided later. Color will be gloss black with flat black stripes and tan leather interior with Recaro sportster CS seats. The rims have gloss black hoops with flat black centers. I will add an integral split spoiler, flush mount glass and do some custom interior work.
      Here’s what I got going so far:
      Max-g chassis, C6 front, triangulated 4 bar 9” rear
      4:11 gears
      Wilwood brakes
      Forgeline ZXP3’s With 335x18 R888’s
      T56 and LS1 from 04 GTO
      Allot of sheet metal, welding supplies and grinding widgets!
      Bringing it home and tearing down. I installed mini tubs and had the hole back of the car bolted together waiting on Jakes rod shop suspension. That didn’t work out, so out came the plasma again to start over!
      Here it is on the Max-G frame. These things are works of art!
      Lil helper getting the front suspension dialed in
      I got as far as I could then ordered these rims and tires so I could finish fitting everything. They turned out way better than I had hoped!
      I cut the lip off the wheel well to make extra room for the tires. A friend suggested welding a piece of brake line tubing to the lip to give it that rounded look. It turned out perfect, but took a bit of time. Welding sheet metal is one thing. Welding a tube to it is something else! Cut the outer wheel wells to match.
      I was able to get the rear bumper brackets made and attach the rear tail pan. I will be fabing all of the internal sheet metal
      This week I should have both quarters, tail pan and outer wheel wells on permanently. Seems like I’ve had those quarters off and on a hundred times. I’m excited to weld the suckers on. Then I will start working on the trunk floor and close internal body sheet metal this weekend.
      Apr 2012
      this looks like a fun project.. whats the drive train going to be?
      Feb 2006
      Idaho Falls, Id
      I've always wondered what you've been up to with this. Glad to see you're getting some where
      Traven
      Jul 2008
      ohio
      wow nice work...
      Jul 2011
      Atlanta, Ga
      This looks like a sweet project!
      Could you share your wheel and tire sizes?
      1967 Mustang Coupe
      2011 Mustang GT/CS
      1971 C-10 SWB Shop Truck
      1970 GMC Suburban (Betty) Tow Rig
      Oct 2012
      Jupiter Florida
      Nice looking project.
      Its hard to find good help but it looks like you are in good hands.
      Nov 2012
      Boogie Down Bronx
      Those Rear Tires are HUGE!!! What's Their Size?
      Jul 2008
      Thanks guys. So far its been quite the learning experience. Never done any body work or this kind of fab before, so its allot of fun but im a bit slow at it. Gunner is my 4 year old. He calls this his hotwheel car
      Tires are Toyo R888's 335/30-R18 rear 275/35-R18 front. Wheels are ZX3P's 10x18 with 7-3/8 backspace for the front and 18x12 with 7" backspace for the rear. They fit perfect and the quality couldn't be higher!
      You working on your car still T Raven? Come by some time if your still in the area..
      Jul 2008
      Quarters should be welded on by the end of the weekend! I'm going to need to order an engine soon. Thinking about a ls7 or something supercharged. Any suggestions? Would like 600-650hp at crank
      Oct 2012
      Jupiter Florida
      Mast has a nice selection that will meet your HP numbers.
      We just orders a LSX 440 X Block 660 HP for a customer. They are great to work with.
      We also have an LS3 Black Label in the 1968 Camaro we are finishing. And I think all you have to do is look at the accelerator and the car want to take off.
      Feb 2006
      Idaho Falls, Id
      Quote Originally Posted by seekins View Post
      Working on my 69 right now and driving the 67. Gonna start on the 67 this fall. I moved back to Idaho Falls, but I'll stop by when I'm up that way
      Traven
      Jul 2008
      Got the quarters and tail pan welded on. I must have had them on and off 200 times! They fit great. This week im starting on the internal sheet metal for the floor and trunk area assuming the bead roller and sheet metal brake show up! Finally, after 4 years get to see some progress!!
      Perth Western Australia
      Country Flag: Australia
      Keep up the great work, it's look awesome.
      Used to be known as tonner
      IN/MI border
      Nice! Love the wheels and finish!
      Jul 2008
      Inner wheel wells are done! They weren't too bad but definetly challenging. I will post some pics! Other than that I don't have allot to report. Waiting on a bunch of parts to come in so I can test fit and not get too far ahead of myself.
      The ls3 crate engine, billet ring brothers goodies and recarro cs sportster seats arrived this week. I have a LS3-B cam bunch of other needed things and whippe charger kit coming from texas speed. Also waiting on willwood pedal assembly with dual master cylinders to get here so I can finish the firewall and floor.
      Jul 2008
      Here are some pics of the inner wheel well.
      Cut the lip off of a new inner to use it as the base for the custom ones
      Punched some holes in it for spot welds and attached where i wanted it to go using sheet metal screws. The screws hold things very tight and are fast to install. I prefer them over anything else.
      Made a pattern and then the real deal!
      Finished inner wells.
      Next week the Whipple charger and some other goodies from texas speed will be here. seats, pedals and almost everything else has arrived so i can make some progress! Still trying to decide if i want to move the wiper motor under the fender or not. The LS3 is here so i cut out the remainder of the firewall to set the motor in and start making a new one.
      Aug 2008
      Iowa
      nice work on the inner fenders!!
      Feb 2014
      Boise , Idaho
      Glad to see your not squandering all your talent on firearms Glen
      Apr 2014
      great job man, love seeing these older cars with new body frames. Subbed!
      Connor
      Any updates on this project?
