      Feb 2007
      floor patch panel question
      I would like to know what most people do when installing a patch on a floor pan. Do you cut to fit and do a butt weld or do you overlap the new section over a portion of the good existing pan and do a spot weld?
      Not sure what the best or correct way would be. I have only done the butt weld before
      Brandon Slater
      1979 Z28
      1972 Nova
      2015 2500 silverado crew cab duramax
      May 2007
      Mooresville, Indiana
      Hey Brandon, I've done both methods and prefer to overlap it and weld both sides. Butting it together just makes blowing through way to easy. My experience is also that seam sealer and lizard skin hide a multitude of sins... Good luck!
      polk county,FL
      I have always butt welded mine.
      Feb 2007
      Thanks Tom.
      yeah I have always had the issue of blowing through with the butt weld on thin sheet metal. I will try the overlap on this one.
      Brandon Slater
      1979 Z28
      1972 Nova
      Jul 2007
      Olathe, KS
      It seems that whatever is most difficult I'll end up doing because it seems like the "right" way. For a pan I end up butt welding it. I hate even knowing the lap weld is there.
      The key to butt welding sheet with a mig, in my experience, has been a moderate amount of heat, pretty close gaps, and absolutely cleanliness. Any rust/dirt/oil really mucks with such a small tack and will ruin the appearance. If you're blowing through you've got it set too hot, or wire speed too low.
      Central Cal
      Self taught myself to weld while working on my ride.
      Patience and Understanding do it right.
      But weld.
      Rhino said it like it is.
      Nov 2012
      Colorado
      I looked at patches, but then thought how hard could it be to replace the whole floor. Definitely a lot of work so far..and someday soon it will be done.
      Jeff
