      Abbotsford, BC
      Ridetech Shockwave TQ series
      I'm having a hard time finding any performance testing on these, anybody see anything? Thinking I might go this route for my Volvo Amazon, I'm running some old AFCO coilovers with circle track valving now. One of the things I always read about with quality shocks is that the clicker adjustments actually work and show results on a shock dyno. Whereas cheap foreign tuner shocks have clickers that don't do much other than look cool. How do the Ridetechs rate? If I don't go air, I am leaning towards just the ridetech coilovers too. ;)
      Des Moines, IA
      There are dyno graphs out there in cyber land somewhere.
      However, I can post new ones up tomorrow when I'm in the shop.
      You will not be disappointed!
      If you don't like what we have we can re-valve them to your specs.
      Or we can get you a re-valve kit and you can do it yourself.
      Abbotsford, BC
      That's what I was hoping to hear. ;)
      1966 Volvo
      Dec 2009
      knoxville, tn
      best money I have spent on my suspension (and I have spent alot!). they are the best bang for the buck out there in a high end shock.
      Tom Hensley
      69 ss/rs clone
      98 ta ragtop
      "attack life....it's going to kill you anyway."
      Abbotsford, BC
      Now the ongoing debate of air vs coil. That will be the hard choice.
      1966 Volvo
      Indiana
      I attached a .pdf graph showing the dyno curve of our TQ triple adjustable shock. It can be had in coil and air configurations.
      Starting at full firm, the rebound, high speed compression, and low speed compression are turned clockwise all the way in. 4 clicks means all knobs were turned counter clockwise 4 clicks, then 8 clicks, etc.
      Herb
      1966 Chevelle 509/T56Magnum
      1963 C10 454/4L80
      PHR CHP CHP youtube
      Abbotsford, BC
      Thanks Herb!
      1966 Volvo
      Des Moines, IA
      The shocks in the coil over and shockwave are exactly the same (though we do valve them differently for front or rear applications.)
      You'll need a way to put air in the Shockwaves. You can use simple Schrader valves (like the old air shocks) and put air in once and be done. . .or you can get a compressor kit so you can adjust them.
      One other option is that you can purchase coil springs and retainers and turn the Shockwaves into coil overs if the price is right on the Shockwaves.
