    Results 1 to 14 of 14
      67 Shoulder Belt Roof Anchor
      Hello, Newbie here,I have a 67 Camaro built in Nov.
      I called Ricks first Gen about the three point safety belts and they assured me that my car being built in Nov. has the roof anchors for the shoulder belt.(yet they wont say where they are located)
      My problem is that I have seen pictures in 67 and 68 Camaros with the shoulder belt anchored in front of and behind the hanger hook. Which is correct location? how did you find it? The car has a like new headliner that I do not want to cut in the wrong spot.
      Any help would be appreciated.
      Press on the headliner you'll feel two holes with a dimple between them.
      Contact Nantooch @ the camaro.net site. He just installed the same seatbelts that you are looking at in his Camaro. He will be able to tell you more specifics about the mounting point locations. Hope this helps.
      seatbelt mount
      Looked at a picture of (Nantooch), Brandon's car the mounts are in front of the coat hanger about 4 inches. He will be able to give you specific
      measurements if you contact him
      Thank you I will!:icon996:
      I will be installing them this weekend and I will let you know how it goes.:icon996:
      Belts are in, but the plastic arm (console side) is deforming at the base when I tighten the bolt down so I am unable to put the little plastic cap that covers the bolt.
      Anyone have any suggestions?
      Seatbelt
      Ed,
      I am trying to find a bushing to keep the bolt from pinching the seatbelt.
      I think that is the problem you are having.Keep in touch. We'll find a solution.
      Thanks Billy
      Billy, the email with pics has been sent, you and Robin have been great to deal with.
      Georgia
      Billy,
      I have the same problem with my '68 Firebird. Has a solution been found?
      [email protected]
      Quote Originally Posted by 68FB400
      Billy,
      [email protected]
      seatbelt cap
      I just got back home from vacation. I don't have an answer yet as we
      don't have a car to install a set in. Maybe the seatbelt end is being pulled down into the carpet causing the plastic sleeve to deform. Try to loosen
      up on the mounting bolt a little. I hope that we or someone can come up with a reason that you are having this type of problem. I will try to look at
      some factory later model Camaro's and see how the mounting point and sleeve are attached.
      Billy
      England
      There should be a sleve that is machined down to allow the belt mount to swivel will find a pic and post
      paul67
      Quote Originally Posted by paul67
      paul67
      I agree, if you look at the factory bolts they are as described above.
      The sleeve (the machined down surface) actually meets the floor mounting point and stops the bolt from actually contacting the face surface of the metal belt base.
      In turn this allows the belt base to swivel.
      Seatbelt mounting
      Guys,
      I am out of ideas. Maybe if you snug the bolt then put a piece of velcro on the back of the seatbelt plastic sleeve as it will stick to the carpet and hold the female latch in the correct position. If I had a car to work with maybe I could give some better advise.
      Billy
