    Results 1 to 20 of 20
      Jan 2009
      Quest for a better ride!
      I have been recently getting big into the pro touring scene with my 1988 Iroc-z camaro. Last winter, I went through every bit of suspension on the car to make the car handle like its on rails. I have achieved that, and my mind is blown everytime I drive it at how well it handles, BUT the ride is extremely rough when just cruising around town (im 27, so thats saying a lot) and on the highway. My goal now is to have a car that i can drive everyday without getting beat up. Also, this car is driven A LOT. Its not just a weekend car, so loosing a little bit of handling for more comfort is ok with me.
      My setup:
      32psi Falken 912 tires
      34mm front/24mm rear sway bars with poly bushings and end links front and rear
      stock lower control arm with global west del a lum bushings
      Eibach pro kit springs: 714 lb/in linear front 1 inch lower/109/177 lb/in progressive rear 1 inch lower (stock isolators front and back)
      Tokico Illumina 5-way adjustable shocks (Set on 1)
      UMI subframe connectors (weld in)
      UMI tubular rear control arms with poly bushings
      UMI rear re location brackets
      UMI adjustable panhard bar with poly bushings
      Any help at all would be appreciated
