    Results 1 to 9 of 9
      Aug 2012
      FS T56 Transmission & parts
      SOLD!
      Okay guys. I am selling my T56 swap setup. This came from a '97 Camaro and has approx 91k. This tranny will work with both GenI and GenII SBC motors. If you have a two piece rear main you will need a conversion flywheel.
      This is NOT compatible with GenIII or newer motors.
      This is complete from the flywheel bolts to the rear u-joint. You will receive the following.
      T56 tranny w/bell housing
      Master and slave cylinders
      Clutch and Pressure Plate consider them cores
      Flywheel Should be resurfaced
      Pedal Assembly
      Driveline
      Torque Arm
      Crossmember
      Paypal accepted. Local pickup preferred but I can ship it at your expense. Ships to lower 48 only.
      I would like $1500. I am in the Medford, OR area.
      Dhamendra N.
      Building my 1st Pro-touring car, 1st Nova, 1st LSx, 1st six speed!
      Aug 2012
      I will be traveling to Vancouver, WA on Saturday 4/13/13 from Medford, OR. I could meet a buyer on the I-5 corridor.
      Dhamendra N.
      Aug 2012
      New lower price! $1500 plus shipping.
      Dhamendra N.
      Dec 2010
      Fredericksburg, VA.
      Do you know what the gear ratios are?
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Aug 2012
      2.66:1 1.78:1 1.30:1 1.00:1 0.74:1 0.50:1 reverse 2.90:1
      Dhamendra N.
      Dec 2010
      Fredericksburg, VA.
      Damn, I need the .80 and .64 OD.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      Aug 2012
      The GM aftermarket unit?
      Dhamendra N.
      Pensacola, FL
      Any interest in selling the resevoir & rubber line from the master cyl?
      Scott
      Aug 2012
      Quote Originally Posted by Z06vet View Post
      Scott
      I am working on a deal for the complete setup. If it does not work out I will let you know.
      Thank you for your interest.
      Dhamen
      Dhamendra N.
