Thread: 69 Camaro no spark
03-29-2013 #1
- Jan 2011
- 3
69 Camaro no spark
Car was fine, starting fine etc etc. Some minor starter kick backs here and there. Then one day it stopped firing. Starter turns over and that's it. So I thought the MSD box went bad. And it begins...
So now was a good time to swap it out to the 6al-2 programmable and an MSD 85551 distributor and rewire it all. Nothing...
So I thought maybe the box was bad out of the box, so I tried another one, same thing. The thing I did notice was when I pull the pick up harness off the distributor the LED on the box would light up (it should be lit , when switch 12v is applied). Plug in the pickup harness it would go out.
Long story short after trying three coils, two 6530 boxes, wiring it straight to the battery , changing the switched 12v wire over and over again, checking TDC setup and everything else under the sun, it still wont spark.
Changed the plugs, switched back to a basic ready to run distributor (brand new one too) and I still cant get it to fire.
OK so what stupid thing am I missing here? I even went so far as to put a new battery in it (desperate!!).
Previously running I had a digital e-curve distributor with a 6421 box and that was running great for about a year or so.
What in the world would stop this from firing!! New everything all new wires, direct to fusebox and battery, theres no excuse. I don't get it.
Engine is a 540 bbc, t-56 trans, starter is new, alternator is new. Everything is new within a year or two.
