Thread: turbo size
08-15-2005 #1
- Aug 2004
- San Antonio, Tx
- 1,193
turbo size
so i ordered my turbos a few months ago and the guy at forced inductions said that 2 T04E turbos will support upto 1000 horse on a 421 small block chevy. so i got them out of the box the other day and noticed a A/R .50 on the compressor housing. i'm wondering if these are the right size, the compressor is .50 A/R, the turbine is .68.
there on master powers web site http://www.masterpower.com.br/eng_framese
810011 TO4E TURBO EX. HIGH-PERFORMANCE TO E.U.A
EX: TO4 64 RT: TA 58,16 MONOFLUXO INLET T4
TURBINE .68 OPEN, COMPRESSOR .50 VOLUTE
i have a feeling there not the correct size for what i want, i'm looking for around 1000 horse when its cranked up but will be keept around 500-700 horse most of the time. what do you guys think?Instagram: CamaroAJ
08-16-2005 #2
Full Blown G-Machiner
- Nov 2004
- Roanoke, VA
- 515
While turbo sizing is a HUGELY application specific type deal keep in mind that with twins you can use some fairly small turbos to achieve the air flow you are after. IMO the A/R for the turbine side is ok without knowing more info on your combination since it will provide a decent spool up rate vs air flow.
Be very cautious of falling into the typical "bigger is better" on A/R ratios and turbo sizing (Im guilty of it too) as most of what you read in the mags is bordering on what 75% of us would put up with on even a weekend toy let alone a driver. While huge turbos with mongo sized A/R gets all the oohhhs and ahhhs from a lot of bench racers I think youll find that staying on the mild side will provide you with a more "fun" turbo car that doesnt take 1/8mi to spool up.
My .02GMC Syclone (currently wrecked thanks to the typical rubber headed VA driver not paying attention to his red stop light...oh and he didnt have insurance either)
#614 11.9 @ 113
New stuff finished 08/06:
4L80E trans w/TCI PCM
Syclone
Tow rig
08-22-2005 #3
Starting The Transformation
- Aug 2004
- Alta Loma,SoCal
- 396
The a/r on the compressor side is not as important and on the turbine side. The compressor wheel is the important part on that sie of the turbo.
1965 Buick Skylark
