      Jul 2010
      Mooresville,NC
      Upgrading to Autometer Setup......
      Hey guys....well been wanting to do this for awhile and since i going be doing autox,road course and other performance driving...its getting time to upgrade from the factory warning lights.....i thinking about going with this classic dash setup...comes complete with new harness and gauges....anyone used this setup? How easy is it to wire and install?
      http://www.classicdash.com/shopping/...er-Gauges.html
      Matt
      1971 Chevrolet Camaro RS-Detroit Speed Equipped
      1966 Chevrolet C-10-Driver/Project truck
      Mar 2011
      Fort Mcmurray, Alberta
      I put this setup in my 1980 Camaro last summer. It was real easy to splice into the existing harness with the instructions they sent. All the wires in the harness are labelled and they came all the connectors required. Its a real nice upgrade to the old gauges. I have the Ultra lite 2 gauges.
      1980 Camaro Z28. LS376/480, TKO 600.
      Jun 2006
      Katy,TX
      I used a blank non drilled from them for my 79 Camaro and custom cut holes for 5" tach and speedo. Used Autometer and Painless universal gauge hearness. Easy enough to cut into factory harness but get the correct crimper for the terminals. Used some extra aluminum in front and behind to stiffen it up some also.
      The holes for the 79 were not quite right on and I had to redrill several and use a scew with a countersunk washer(like tirm panels often use) to cover the larger hole.
      1965 GTO project car
      2004 Pulse Red GTO
      Aug 2008
      jacksonville,fl
      I wired mine the hard way. If you think of it one wire at a time, it's not so complicated. Welcome to the good gauge club.
      Jun 2006
      Katy,TX
      Here's how mine looked
      2004 Pulse Red GTO
