Thread: EFI fuel rail plumbing
03-07-2013 #1
I've read several contradictory points of view on this. Maybe it's splitting hairs...
Some say to run a single deadhead fuel pressure line up to the rails with the regulator back by or in the tank to eliminate problems with heating the fuel on long duration trips.
Others advise to run the feed through both rails and put the regulator after for best accuracy with fuel pressure at the injectors because the deadhead setup can cause fluctuation.
I've also heard a Y in front and back with the reg after is best.
I would rather not have pressure fluctuations or hot fuel problems. What about a compromise? I'm thinking running the feed to the regulator just before the fuel rails would keep the bypassed fuel from heating up in the rails, and should stay fairly consistent pressure-wise by only running the length of the rails deadheaded. Has anyone tried a setup like this? Any thoughts?
For my application the pump is a Walbro 255HP to feed 500-550hp. 3/8 feed and 3/8 return already plumbed.
