    Results 1 to 10 of 10
      Birmingham, AL
      Control arm paint options
      I need to paint my c5 control arms since I have brand new uppers and grimey lowers. No chance they would ever look the same. I was thinking about black crinkle. Subframe is matte black. Will this hold up? Any suggestions on getting the grime off? Any suggestions on painting aluminum?
      Stephen
      Mar 2004
      Mid-Michigan
      I would suggest having them bead blasted. They will look brand new afterward and a coat of clear will help keep them looking nice.
      Black Krinkle has a nice look but, if you have ever tried cleaning it, you will stay away. All of those little crevices really hold the dirt and the only way to clean it is a power washer. Nine times out of ten the power washer will blow the paint off anyway so it is a lost cause.
      Mark:
      This my Bad Ast thread...
      This is my Fotki album...
      http://astroracer.fotki.com/
      Birmingham, AL
      I thought about bead blasting, but you can't remove the ball joints on c5 arms. You are right about the texture. Maybe I will look for a clean silver or grey.
      Stephen
      Mar 2004
      Mid-Michigan
      Mask the ball joints and inner pivots with duct tape and don't hit them directly. Easy to do, I've done it many times.
      Mark
      Mark:
      Birmingham, AL
      Now to find somebody with a blast cabinet.
      Stephen
      Nothern California
      Easy off oven cleaner used to work real well on cleaning tansmission cases. Give that a try
      Guy S.
      68 Camaro LS1, T56, Forgeline WC3
      69 El Camino BBC 4spd A/C Cruise SOLD
      2012 Dodge Crewcab Diesel 4x4
      Aug 2006
      Vinland Kansas,66006
      Scotch brite works awesome.Could DA with 120grt first then 220, then scotch brite.Shephen Thanks for becoming a customer.
      Wake Forest,NC
      If you want to be lazy this stuff works well http://www.eagleone.com/mag-wheel-cleaner
      Birmingham, AL
      I tried degreaser and scotch brite. I will probably give it another good scrubbing and then get a little more aggressive.
      Stephen
      I had an old car guy once tell me that lamp oil will take gasoline stains off of a cast aluminum manifold. It worked for me, may work on your control arms? Not saying i would be better than any other methods suggested.
