    Results 1 to 13 of 13
      Feb 2011
      Removing Dynomat tips?
      I need to remove some dynamat type sound deadner to have some welding done to my car. Anyone have any tips or tricks to doing this? So far I've been using a heat gun and putty knife. I'm hoping there is a better way. This is making a mess but it is getting it done slowly.
      Norway
      Country Flag: Norway
      Heat gun and a putty knife.
      Arne A Hjemaas
      Milwaukee, WI USA
      That is exactly what I'm worried about using this stuff.
      I really don't think there is any easy way to remove it.
      1969 Camaro SS, 350(NOM), M21, 12 Bolt Posi, 01B (Jan 69) LOS Build
      Jul 2012
      Greenwich CT and NYC
      My shop removed Ll of the dynamat extreme from my car and use nitrogen to freeze it cold and scrape it. Heat was a nightmare they said and the colder it got the easier it broke the bond. Look into that
      Feb 2011
      It's too late to try the cold, but if I ever have to do it again, I'll start there.
      Thanks.
      Jul 2008
      BATON ROUGE
      Dry ice works good!
      Tim B.
      Chit-ca-go
      I can't seem to find dry ice locally. Any other ideas?
      1971 Firebird
      2017 Slipstream SS
      bowling green,ky
      had to do the whole floorboard on a chevyII what a nightmare. Good luck!!
      69 Camaro
      03 z06
      90 mustang coupe
      Jul 2013
      Gilbert, AZ
      Good luck. Interested to know what happens, although my thoughts on using Dynamat, or anything similar is that the car will hopefully be long gone before I ever need to scrape the stuff off.
      Josh Campbell- Pushing the limits of my HOA since 2011
      71 Firebird- 455, Ridetech front suspension. https://www.pro-touring.com/threads/...04#post1124504
      67 Camaro RS/SS clone, Speedtech front suspension, coilovers, soon to get LT1/T56.
      82 Z28- cheapie beater, soon to get a 406.
      66 Mustang coupe- 393, T-5, sold. https://www.pro-touring.com/threads/...-Coupe-GT393-C
      Den Helder, the Netherlands
      Country Flag: Netherlands
      Aug 2011
      North Platte,NE
      Acetone.
      Mar 2012
      Chicago, IL
      Dry ice in Chi:
      http://www.yellowpages.com/chicago-il/dry-ice
      Thought I saw it in Mariano's but don't see it listed.
      I used an oscillating multi-tool with a scrapper blade when I removed the mat from my floor.
      Jeff
      '64 Buick Skylark Convertible, ZZ383
      700R4, 4 wheel discs, 3.73 Posi
      A/R Torque-thrusts & BFGs
      May 2011
      Here is an idea
      Guys, when I had what was left of my floor boards and rear fender wells it had the 50 year undercoating on ( maybe old Zebart) I used a pneumatic "needle scalier" in the shade(little heat as possible) and the old undercoat popped off in small pieces from the vibration and scraping from the tool. Bought this tool at Harbor Freight and remember a pack of replacement needles is like 5 bucks. The body was on a rotisserie and where the sun hit it, did not work as well because the undercoating got soft. So after I discovered that I worked in the cool shaded areas and rotated the body and let the warm areas cool off ( and I had a beer). The Navy uses a HUGE version of this tool to clean the bottoms of ships. It may work for you....if it don't its a cheap tool anyway.
      64 F-85 post car Resto-Mod project-my RV when I retire
