    Results 1 to 17 of 17
    Thread: Dead space!!
      Jan 2013
      Dead space!!
      I need a little help from the brake gurus on my brake system. I have front and rear brakes from ABS on my 72 Camaro. 13" with 4 piston calipers on all four corners, 1 1/8" bore dual master with vacuum power.
      My problem is about 1 1/2-2" of dead pedal before the brakes start doing their thing. It was much worse before I drilled a new hole in my brake pedal shaft in a lower position to give the booster rod a straighter push into the master, but it still has more than it should, in my opinion. I have bleed the whole system several times, but it makes no difference.
      Anyone have this problem in the past? Everything is new with less than 130 miles. Could it be a bad booster? Or......... Thanks in advance for the advise.
      Beach Park IL
      Sounds like to much free play between the booster and master cylinder.
      Donny
      Jan 2013
      Interesting theory . How would I check that? The booster/master came as a complete unit from ABS and I never separated them. I just double checked for tightness and called it good.
      Beach Park IL
      We have a tool, I can't find a a picture of it at the moment. We got it from MasterPowerBrakes. You are looking for .020" to .025" clearance. between the piston in the master and the pushrod or pin that comes out of the booster.
      Donny
      Jan 2013
      How would you go about adjusting clearance. If that is my problem, I would assume too much clearance?
      Jul 2010
      North Texas
      You say you didn't separate the master from the booster.
      It may have the wrong push rod in there, or it's missing completely.
      Dean P.
      '72 Buick Sun Coupe GSX
      My build thread: https://www.pro-touring.com/showthre...ck)&highlight=
      Jan 2013
      It could be that, I guess. I did have to extend the rod that connects the booster to the brake pedal because the pedal would be just about right on the floor if I hooked it up to the booster at the length it came from ABS.
      Jan 2013
      Anyone else with some ideas? I want to fix this problem once and for all. Im almost at the point of buying a new booster/master set-up. The more I think about it ,the more I think ABS sent me the wrong unit. It has been a battle with that company from the start with this brake setup.
      Beach Park IL
      So that wasn't the problem?
      Donny
      Jan 2013
      I havent checked it. To be honest, I dont know how to check the clearance. Are you talking about the freeplay in the pushrod?
      Beach Park IL
      Here is a quick writeup of how to use the tool. CPP part number CP2003.
      http://www.classicperform.com/TechBo...ot.htm#pushrod
      Here is a generic, less precise way to do it. If you use this method and make progress then you are on the right track. http://www.doityourself.com/stry/how...rod-adjustment
      Diagnosing problems in any system must be methodical or you will waste time and money chasing your tail.
      Let us know what you find.
      Donny
      Jan 2013
      Thanks Donny. I will separate the master and booster and lengthen the rod, then check for a difference. First up, I will have my son help me do the fluid test in the master. At one time ,going back and forth with ABS the tech had me check the fluid rush thing and it moved fluid but Im not sure how far my son pushed the pedal during the test. I will have to come up with a way to regulate that variable . Thanks again.
      Jan 2013
      There shouldnt be any reason for fluid to come out of the system by separating the master from the booster, right? I just want to make sure before I do it because I dont want brake fluid eating the paint off my frame. I should be able to manipulate the master by gently bending the brake lines to get to the rod.
      Beach Park IL
      No fluid will come out when separating the master from the booster.
      Donny
      Oct 2009
      New Derry, PA
      While you have it apart, check that the booster output rod moves immediately when you press on the brake pedal. No reason I can think of that it shouldn't, but that will at least eliminate lag through the booster and pedal as a possibility.
      Jan 2013
      Will do. Thanks for the input. If I can shake this Superbowl hangover, I might work on it this evening.
      Jan 2013
      Donny, it seems to have worked. I separated the booster/master and found the adjustment bolt at the end of the rod was somewhat loose and had a sideways taper. I straightened the taper out and lengthened the rod by 3/16ths, to take a big swing at it, and the brakes feel very good now. Unfortunatly the 72 is really low on fuel and I have a sick 6yr old with the flu, so I just drove around the yard and hit the brakes 10-12 times. I will drive some distance at some point next week to make sure I didnt go too far with the adjustment.
      Thanks again for the assist! David
