Results 1 to 16 of 16
Thread: Baer Brakes hard pedal?
12-12-2005 #1
- Aug 2004
- So. Cal
- 49
I've recently installed the baer track front and sport rears.
I have power brakes with the factory style booster and baers proportioning valve to the rear. I'm not sure how much vacuum the engine makes, but it is a 383 with a comp cams XE274. When I first start the car the pedal is low but there, then after I rev. it a little the pedal feels good. As I start to drive though I'd say it feels hard and it is really hard to get it to lock up.
I know hydroboost would be great, but $$$$$. Is it worth trying manual brakes? I'm not sure what that's like, or should I try a smaller master cylinder? Is there any difference of vacuum from the back of the carb vs. the intake?
thanks,
chris
12-12-2005 #2Sounds like if you drove with your foot on the gas and the brakes your problem would be solved!! Totally kidding:icon_razz
Vacuum gauges are pretty easy to come by....have it checked. You should see between 15-20 inches vacuum. If not... this may be your issue. Since you are getting better pedal feel when revving the engine I would bet that vacuum is low from the get go. What is the lift and duration of the cam you installed?Laramie Torres
12-12-2005 #3
- Aug 2004
- So. Cal
- 49
the duration is 230 / 236 at 0.50
or 274/286 from comp cams
lift .490 w1.5rockers, 110 degree sep.
12-12-2005 #4
- Nov 2004
- NW Arkansas
- 1,742
Originally Posted by cakneller
I'm sure that is border line on vaccum.....I would get a gauge and check it at idle and low speeds
12-12-2005 #5I bet a gauge will show that you are producing around 8-12 inches vacuum(a bit low IMO), most likely the cause of the issue you are having. Give Paul over at Hydratech a call, I think you'll be pleasantly surprised that the price is not all that bad.
Laramie Torres
12-12-2005 #6
- Aug 2004
- So. Cal
- 49
thanks.
Do you think manual brakes are worth a try?
Also, how much vacuum is nedded optimally?
12-12-2005 #7
With the right bore MC....YES. What bore MC are you running?
17-20 inches of MercuryLaramie Torres
12-12-2005 #8
- Aug 2004
- So. Cal
- 49
I think it's 15/16" from Baer.
Came with the kit.
12-12-2005 #9
