      Indiana
      How to pull a pump on a 4l60e
      How do you pull the pump on a 4l60e?
      dayton ohio
      remove pan
      remove filter
      remove tcc solenoid (2-10 mm head bolts)
      now the tricky part, i usually slide a large screwdriver under the pump and "pop" it.
      are you rebuilding/resealing?
      kevin
      POLITICIANS & DIAPERS BOTH NEED TO BE CHANGED, AND FOR THE SAME REASON!
      Indiana
      Thanks Kevin. Rebuilding. Broke the sun shell, and figured I might as well put in new friction discs too. Any other tips? None of my specialty tools are for automatics. If I need any of the tools (such as J ####) listed in the back of the ATSG manual where do I find them? Or can I get lucky and improvise on all of them?
      dayton ohio
      we made the piston spring compressors with misc stuff from lowe's. a friend od mine still works at the chevy dealer and i can get the stuff i need anytime. if you have any specific questions pm me.
      kevin
