    Results 1 to 20 of 244
      Sep 2007
      York, Pa
      Quote Originally Posted by carguykeith View Post
      Those 345's look amazing under there! Also I hope you are a professional welder, because those are beautiful welds and make my junk look like... well... junk...
      If you haven't welded those LCA mounts on yet, I would play with a 4-link calculator to optomize your anti-squat. I had to weld on lowering brackets to my axle LCA mounts but you could just raise your frame mounts and get the same results.
      I did get adjustable LCA mounts for the axle. They are an option from Moser when you order the rear. They are pretty nice you can see them in the bottom of the pic. I ordered the brackets loose so I can locate them where I need them. I did send my sway bar mounts to them and they welded those on to my center-to-center dimensions. I would do buisness with Moser again.
      Justin Snow
