      Jul 2012
      Chicago
      Forgeline ZX3R for 68 Chevelle fitmen
      Hey guys I have a 68 Chevelle and was looking into getting these set of forgeline wheels would they fit my 68 Chevelle SS, I have tubular control arms all around with coilovers, with strange axles and wilwood kit numbers
      140-7675-D R
      140-7149-D R
      I need help before I buy
      FRONT
      18x9, offset 36, B.C 5/4.5, Hub 70.6,
      REAR
      18x10, offset 44, B.C 5/4.5, Hub 70.6,
      Ontario, Canada
      Isn't that a Ford bolt pattern?
      Andy Pooni
      Jul 2012
      Chicago
      Yes but was wondering if there is any way to make it work
      Ontario, Canada
      The bolt pattern is one issue. I think the backspacing is another. You would have to get new centre section made with the correct bolt pattern and then have them rehooped for the correct backspacing. At that point you have a completely new wheel. Probably just easier and cheaper in the long run to order a new set to your specs.
      Andy Pooni
      Jul 2012
      Chicago
      I called forgeline and since I'm using strangle axles which are drilled for different bolt patterns and wilwood slotted rotors which I can change bolt pattern and with spacers I should get the correct bolt pattern to make them work plus for the deal I'm getting them brand new can't go wrong
