      Oct 2008
      Recommendation for mesh style pro-touring wheels
      Seems like there are several vendors making wheels today andI was curious to know if anyone could recommend cost effective wheelproviders. I realize Forgline is thebest but unfortunately I can't really afford there wheels and ultimately I ammore seeking the look rather than the performance values they bring. I am looking for 19" or 20 " 5 on 5if that helps. maybe something around 500-600 a piece would be the max. not sure if that is even possible but I figure it's worth a try.
      I've been looking at the Beyern Mesh wheels for my car - don't know if that's what you're looking for but they are a nice looking wheel and run about $225 each from Discount Tire Direct. If my figuring is right, their 15mm offset wheels in 18x9.5 should fit a First Gen F-Body with no problem. You didn't mention your car so I don't know if this will fit yours or not. The only negative I can find is that they are 5x120mm instead of 5x120.6mm (5x4.75).
      GeoffP
      68 Camaro - LS1/T-56
      Oct 2008
      Quote Originally Posted by bloibl View Post
      1971 C-10 and we are tubing out the rear and was thinking about 18 on the front
      Oct 2007
      check out CCW.. great wheel for the coin...
      67 Camaro In progress
      Apr 2008
      Danville, CA
      Try Lynn at Intro Wheels. Great quality and pricing.
      Apr 2012
      Woodstock, IL
      We have used XXR wheels on several lower-budget builds, and they're pretty good quality. Weldcraft Wheels out of Michigan can widen them if you want wider than 9-10". Many local wheel/tire companies offer them.
      http://image.hotrod.com/f/featuredve...+rear_view.jpg for an example of a mesh style that I think you're referring to!
      -Dale
      SchwartzPerformance
