    Results 1 to 1 of 1
      Oct 2008
      AUTOPAGE RS-1000 1Mile - HIGH END ALARM
      6 Channel Alarm and Remote Car Starter with 5 on-board MICRO relays for parking lights, starter, accessories, ignition 1&2 and one additional relay / socket for starter disable.
      C3 Compatible with On-board Serial Port for AP Data Link Data Bus Integration
      Two-way paging receiver and transmitting remote with 3-color LCD screen using FM frequency bands for transmitting and receiving at 900 megahertz. Unit will transmit and receive up to 1 MILE. Unit also includes 24-hour clock with meter minder and temperature indicator and countdown run timer.
      New MANCHESTER CODE encoder.
      NEW STYLE Two-way, window mount SUPER EXTENDED RANGE transceiver antenna module.
      One 5-button extended range FM, standard 900-megahertz SLIDE COVER remote transmitter.
      SIS-11 Super Intelligent Sensor with dual stage shock / glass sensitivity.
      Discrete Temperature Sensor that communicates in-car temperature with LCD remote.
      Window-mount Knock Sensor for driver paging.
      Plug-in super bright mini-BLUE LED and push-type valet/override switch.
      TWO-WAY O.L.E.D. REMOTE OPERATION:
      5-button configuration with selectable Button Lock to prevent accidental mis-use.
      Uses a rechargeable battery via Mini USB type connector w/ wall charger included.
      Battery life indicator and power save mode
      Full color (O.L.E.D. Organic Light Emitting Diode) with over 100 icons and animation screens.
      Optional Two Car Operation with LCD transmitter only
      Transmits on FM band and receives on FM band.
      24-hour digital clock with count down timer for parking meter reminder. The clock doubles as a temperature indicator for monitoring in-car temperature. Displays in Fahrenheit or Celsius.
      Multiple audible confirmation tones as well as vibrator mode for paging.
      2-way Transmitter Range Check Indicator
      ALARM FEATURES:
      Six Channels of outputs (3 dedicated to lock/unlock, trunk and remote start / 3 auxiliary outputs)
      Dedicated function buttons on LCD remote and 4-button standard remote transmitter.
      Code learning / Anti-scan receiver with programmable code hopping.
      Back-up memory system
      Selectable Chirp Confirmation (OEM Style lock only chirp confirmation)
      Comfort Feature with OEM systems having key / remote control power window roll-up
      Dedicated remote panic and car locator
      Passive arming by-pass from the remote
      Parking light flash with dual polarity relay on-board
      Plug-in dual stage SIS-11shock sensor with sensor by-pass from the remote
      Starter disable output with relay and socket included
      Dome light illuminated entry output
      Dual polarity (+/-) door lock outputs with optional driver s door priority two step unlock
      Additional positive and negative inputs
      500 mA grounded outputs for starter disable and door lock/unlock
      Programmable momentary, latched or timer on 3 auxiliary channels.
      Programmable manual / passive arming with true last door arming with auto re-arm on
      Programmable Single / Double Pulse Unlock (7 new timing adjustments)
      Programmable Parking lights (flash or constant)
      Programmable Pathway Illumination (on / off)
      Programmable voltage sense for delayed dome lights (on / off)
      Programmable horn and siren chirp delete
      Programmable ignition control lock and unlock
      Programmable pulse time for lock and unlock (.9 sec. / 3 sec.)
      REMOTE CAR STARTER FEATURES:
      5 On-Board Relays:
      Ignition 1
      Ignition 2
      Starter
      Accessory
      Parking Light
      3rd Ignition (-) output
      Dedicated Second Start wire
      Dedicated Ground out when running
      GM- Non starter wire timing compatible
      Ground when start (-) output
      New Turbo Timer feature
      2nd Accessory (-) output
      Selectable one or two push Safety Start
      Programmable gasoline or diesel with 10, 15, or 20 second Wait-to-Start
      Hood pin switch safety input (pin switch included)
      Selectable RPM / Voltage Start
      TO VIEW MORE SPECS CLICK LINK BELOW
      http://www.sonicelectronix.com/item_9303_AutoPage-RS-1000-OLED-with-ONE-MILE-RANGE.html
      List Date: 11/19/2012
      For more info, check out this listing in the Pro-Touring.com marketplace: AUTOPAGE RS-1000 1Mile - HIGH END ALARM
      On Sale For: $220 + $0 Shipping
      Retails for: $280 | You Save $60 | That's a 21% Discount!
