    Results 1 to 9 of 9
      Dec 2011
      Umatilla, Florida
      Custom LS2 Cold Air Intake
      As part of the project with the LS2 transplant we had to fabricate from scratch a cold air intake. Here's what we did
      We bought some .50 wall 4" DOM Aluminum tubing.
      Thats a BIG tube
      We welded in the LS7 slot type port for the MAF
      Put a mounting tab on the end close to the filter
      This port is for the crankcase vent intake.
      Mocked up on the car
      All welded, ground, sand and test fitted.
      We painted the cold air intake with bedliner to give it a rougher finish, just didn't want it smooth.
      Spectre 8" double cone filter. we did remove ALL the branding on it as well.
      We think the results speak for themselves.
      Follow our build thread.
      https://www.pro-touring.com/showthre...-Gen-LS2-6-spd
      OldGuy Garage
      Umatilla, Florida
      Metamora, Illinois
      Dec 2011
      Umatilla, Florida
      Quote Originally Posted by rocketrod View Post
      Awesome work!!
      Thank you sir !
      OldGuy Garage
      Umatilla, Florida
      Eastern Virginia
      That looks great.
      Scot
      86 Monte SS
      Birmingham, AL
      Feel free to PM me what it would cost for one of those.
      Stephen
      Dec 2011
      Umatilla, Florida
      Quote Originally Posted by srh3trinity View Post
      You really don't want to know ;-0
      Material costs around 100.00 plus the LS7 blade style MAF, MAF fitting, the AF, silicone tubing, and clamps, labor about 7-8 hours all said and done.
      You also have to get your MAF scales redone as the LS7 MAF runs at a different freq, and the tables are different.
      Also unless the car is here, you cant get it exact. We had to cut and fit the tubing to the car so it fit perfectly.
      We can do it however.
      OldGuy Garage
      Umatilla, Florida
      Jun 2010
      Deployed
      Quote Originally Posted by oldguy View Post
      Looks awesome! Spectre does sell kits for alot of cars that look just like that....At least you can say you did it your self!
      Does the $100 parts investment include that filter?
      1970 Camaro/DSE build
      Dec 2011
      Umatilla, Florida
      Thanks Much!!
      This is a custom car we are building for a client. If we could have sourced one that looked good we would have as it would have been cheaper for sure. The spectre filter was 35.00 on the bay. Tubing was 100. It is 4" diameter. Spectre has no kits without extra seams the require silicone tubing. Wanted a one piece.
      OldGuy Garage
      Umatilla, Florida
      Aug 2008
      jacksonville,fl
      Air inlets can be cookie cutter or to each their own , I'm a fan of the 2nd. Your's flows all it'll ever need, get's weather safe cool air, & could outlast the car.The texture probably looks a whole lot better with the shape of the pipe & the rest of the underhood than if you'd spent another 4 plus hours sanding & buffing.
      The worst part about your inlet is the average person can never truely appreciate the work it takes to make a part like that.Even doing a part to be texture coated can be just as much work to make look correct as it would be to polish.
      The best part about yours is it'll never be called wierd or strange like mine.
