    Results 1 to 15 of 15
      What diff do you use?
      Was interested in seeing what everyones runs for a differential...open, locked? What locker is best for cornering, etc.? Is it best to leave peg legged to avoid understeer?
      Money, girls and cars...big ol' long cigars!
      1964 Mercury Comet
      90's 302HO, F303, Vic Jr, AFR 165's, 650DP, full roller, full MSD, WC T5
      18x8 245 up front, 18x9 275 out back
      KYBs, sway, 620 coils, stiff leafs relocated inboard
      13" Late Model Cobra Brake Setup
      Hard to go wrong with an Eaton limited slip for all-around driving.
      Miami, Florida
      I'm using a Detroit Tru-Trac 9" Ford.
      Kevin.
      69 Firebird "Eternity"
      Jul 2002
      Mesquite, TX
      Got a True-Trac for my 12 bolt, but I haven't installed it yet so I can't give a review. It sure looks nice though.
      Nov 2004
      Dallas Texas
      rear diff
      8.5" GM 10 bolt factory posi 3.42 gears
      SoCal
      Another Detroit Tru-Trac 9" user here...
      Dec 2002
      Lost Wages, Nevada
      12 bolt = Eaton LSD
      Ford 9 = Tru-Trac
      Oswego il
      factory ford limited slip blueprinted with extra clutch packs, nodular case, blueprinted pinion support. set it up while drag racing the car, we'll see how long it holds up turning corners.
      Locker here.
      jp
      ​John Parsons
      Jul 2002
      Muskegon, MI
      Spool. 4.11 gears. 8.2 rear end housing with mosier axles and c-clip eliminators.
      May 2004
      Dallas, TX
      9" Ford Traction-loc (limited slip)
      LOL-I'm gonna hear it from somebody...7.5 GM with Eaton posi, 1" Richmond ring spacer and 3.73's w/stock axles. I went with the lightest rear with the strongest of three styles of clutch packs GM used and with synthetic fluid, I haven't grenaded it yet! You could say it's either not making enough power or it's built very tuff! I prefer the latter. After talking with the dirt track guys about how heavy a 9" is and the parasitic drag on the motor to turn it, I opted to build a rear that is fairly light and responds quick. It's going strong for 9 years so far....Jabin.
      Gmachinz Sales and Performance
      "updating the level of performance..."
      [email protected]
      *never argue with an idiot-they'll drag you down to their level and beat you with experience!*
      NC, in a house.
      Got a locker in my 9", it's horrible in as short a car as a Monza. Gonna pick up a true trac soon. Had an old racing geared diff (gleason?) That was worn out, but tried it anyway. WOW! It was great, even worn out! (lotsa backlash, shedding metal) I could just dump the clutch from a side street, front wheels cut completely burning the tires, and it would simply let the back end slide out a little, not even full lock, and tuck back in, still burning 'em! The Locker, this would be suicide, or at least a doughnut. I can't explain it, but the geared posi's are so much more drivable!
      No clicking/pull when lifting/reapplying throttle in a turn either. The locker is solid, reliable, but has a home in 4X4's or pro/streeters/drag only. It makes the daily grind miserable.
      Just my .02 ppm
      Laramie, WY
      I was wondering this also: what would be better open, LS, full posi??? for pro-touring.
      Tim
      89 Lincoln Towncar pro touring project ( new info found for handling)
      95 Explorer XLT OFF-Roader
      95 Chevy Suburban LT 4X4
      07 Harley XL1200L Low 08 Harley XL1200N nightster
      Would you vote for someone who doesn't stand up for the flag?
      Dec 2002
      Lost Wages, Nevada
      Well, first off..........
      A limited slip is a posi. They are the same thing. There are not half and full posi's either..... its either an open, a traction biasing unit (gear, forcing cone or friction platen type) or a mechanically locking.
