    Thread: Oil pan?
      Oct 2012
      Pittsburgh, PA
      Oil pan?
      Hello everyone, I'm new around here and had a question about oil pans. I have a 68 Nova with stock subframe that will see almost all street use with maybe a visit to the strip on occassion. I have used the retro lsx(holley now) pan in the past with good luck, but I would like to have a little better baffling in the pan. I have narrowed it down to the MAST pan or Autokraft pan. Just wondering what kind of experience anyone has had with the two pans. Thanks
      Central Indiana
      Welcome to the site! I see your fairly new and your first post. Im going to vote for the Mast pan... Its all I use in my shop. If you decide to go with the Mast pan I can get one dropped shipped to you.
      savannah,ga
      we use the autokraft pan, mainly because it is almost flush with the crossmember.
      Feb 2008
      Texas
      It seems the autokraft pan has a litlle bit shallower sump and has better baffling and the mast one has an o-ring. Someone on ls1 tech says the mast pan has a depth of 5.75inch at the oil drain plug . The autokraft is 5.5". I don't see the depth on mastmotorsports website though, its kind of odd that they don't have it. Because of that I would choose the autokraft pan. By the way I have a canton pan which is like the autokraft.
      http://www.mastmotorsports.com/2010/..._pan_views.pdf
      http://www.youtube.com/user/cutlassrkt?feature=mhee
      69 cutlass - 5.3l L33, Jakes stage 3 4L80e, 275/40/17 proxes tq
      Nov 2011
      Glendale, AZ
      On that link that you sent it has the depth dimension of 5.75" on the mast pan.
      Quote Originally Posted by 69cutlassrkt View Post
      Feb 2008
      Texas
      Oh i see the depth now
      Central Indiana
      The Mast pan does not hang below the crossmember..... it is baffled well and has the added benefit of adding bottom end strength/structural integrity as GM designed it. I like the look of the other pans, but not willing to sacrifice the strength the cast aluminum pan offers over a sheet metal pan.... and they look great as well.
      Oct 2012
      Pittsburgh, PA
      Thanks for the replies everyone. I really like the idea of keeping a cast pan like the factory designed. Just wanted to make sure it would fit well.
